centos6.0 64位安裝lnmp一鍵安裝包出錯(cuò)
反復(fù)安裝了好幾次,都是這樣
我的安裝過程是這樣的:
1.下載WDLINUX 6.0 base版本的ISO(因?yàn)榘惭b5.6集成LNMP+WDCP版本的ISO成功之后,總是新建站點(diǎn)無法訪問到首頁,系統(tǒng)還是繼續(xù)默認(rèn)/www/wdlinux/default這個(gè)目錄,不肯自動(dòng)解析到新建的虛擬主機(jī)站點(diǎn)根目錄去,新建的站點(diǎn)在vhost目錄下的配置文件已經(jīng)存在,配置正常并且正確.本人太笨,實(shí)在是找不到原因)
2.使用SSH命令"wget http://dl.wdlinux.cn:5180/rpms/rpm_install" 和 "sh rpm_install"安裝過程中,出現(xiàn)一兩個(gè)錯(cuò)誤,一個(gè)是兩個(gè)包沒發(fā)現(xiàn):
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
Package sudo-1.7.2p2-9.el6.x86_64 already installed and latest version
Package wget-1.12-1.4.el6.x86_64 already installed and latest version
Package libtool-ltdl-devel-2.2.6-15.5.el6.x86_64 already installed and latest version
No package libmcrypt-devel available.
No package libmhash-devel available.
Resolving Dependencies
另外一個(gè)錯(cuò)誤是:
100%[======================================>] 5,573,833    415K/s   in 13s
2011-09-19 13:04:44 (415 KB/s) - 鈝dcp-1.1-1.noarch.rpm鈙aved [5573833/5573833]
Preparing...                ########################################### [100%]
   1:mysql                  ########################################### [100%]
chown: cannot access `/www/wdlinux/mysql/var': No such file or directory
Starting MySQL. ERROR! Manager of pid-file quit without updating file.
/www/wdlinux/mysql/bin/mysqladmin: error while loading shared libraries: libssl.so.6: cannot open shared object file: No such file or directory
warning: %post(mysql-5.1.55-1.x86_64) scriptlet failed, exit status 127
============  mysql install OK  ==============
error: Failed dependencies:
      libcrypto.so.6()(64bit) is needed by nginx-0.8.54-1.x86_64
      libssl.so.6()(64bit) is needed by nginx-0.8.54-1.x86_64
============  nginx install error  =============
[root@localhost ~]#
我是不清楚,為什么會(huì)安裝失敗中斷,從字面上判斷,就是缺少這兩個(gè)包沒下載到,源里面難道沒有嗎?
PS:我直接復(fù)制SSH里面的文本上來了,就不截圖了,怪麻煩的,還要上傳,下面是SHH顯示的信息全文(最前面一點(diǎn)看不到了,前面沒錯(cuò)誤信息):
--> Running transaction check
---> Package freetype-devel.x86_64 0:2.3.11-6.el6_0.2 set to be updated
--> Processing Dependency: freetype = 2.3.11-6.el6_0.2 for package: freetype-devel-2.3.11-6.el6_0.2.x86_64
--> Processing Dependency: zlib-devel for package: freetype-devel-2.3.11-6.el6_0.2.x86_64
--> Processing Dependency: libfreetype.so.6()(64bit) for package: freetype-devel-2.3.11-6.el6_0.2.x86_64
---> Package gd-devel.x86_64 0:2.0.35-10.el6 set to be updated
--> Processing Dependency: gd = 2.0.35-10.el6 for package: gd-devel-2.0.35-10.el6.x86_64
--> Processing Dependency: libXpm-devel for package: gd-devel-2.0.35-10.el6.x86_64
--> Processing Dependency: libX11-devel for package: gd-devel-2.0.35-10.el6.x86_64
--> Processing Dependency: fontconfig-devel for package: gd-devel-2.0.35-10.el6.x86_64
--> Processing Dependency: libgd.so.2()(64bit) for package: gd-devel-2.0.35-10.el6.x86_64
---> Package libcurl-devel.x86_64 0:7.19.7-16.el6 set to be updated
--> Processing Dependency: automake for package: libcurl-devel-7.19.7-16.el6.x86_64
--> Processing Dependency: libidn-devel for package: libcurl-devel-7.19.7-16.el6.x86_64
---> Package libjpeg-devel.x86_64 0:6b-46.el6 set to be updated
--> Processing Dependency: libjpeg = 6b-46.el6 for package: libjpeg-devel-6b-46.el6.x86_64
--> Processing Dependency: libjpeg.so.62()(64bit) for package: libjpeg-devel-6b-46.el6.x86_64
---> Package libpng-devel.x86_64 2:1.2.44-1.el6 set to be updated
--> Processing Dependency: libpng = 2:1.2.44-1.el6 for package: 2:libpng-devel-1.2.44-1.el6.x86_64
--> Processing Dependency: libpng12.so.0()(64bit) for package: 2:libpng-devel-1.2.44-1.el6.x86_64
---> Package libxml2-devel.x86_64 0:2.7.6-1.el6 set to be updated
---> Package ncurses-devel.x86_64 0:5.7-3.20090208.el6 set to be updated
---> Package openssl-devel.x86_64 0:1.0.0-4.el6_0.2 set to be updated
--> Processing Dependency: openssl = 1.0.0-4.el6_0.2 for package: openssl-devel-1.0.0-4.el6_0.2.x86_64
--> Processing Dependency: krb5-devel for package: openssl-devel-1.0.0-4.el6_0.2.x86_64
---> Package patch.x86_64 0:2.6-6.el6 set to be updated
---> Package automake.noarch 0:1.11.1-1.2.el6 set to be updated
---> Package fontconfig-devel.x86_64 0:2.8.0-3.el6 set to be updated
--> Processing Dependency: fontconfig = 2.8.0-3.el6 for package: fontconfig-devel-2.8.0-3.el6.x86_64
--> Processing Dependency: libfontconfig.so.1()(64bit) for package: fontconfig-devel-2.8.0-3.el6.x86_64
---> Package freetype.x86_64 0:2.3.11-6.el6_0.2 set to be updated
---> Package gd.x86_64 0:2.0.35-10.el6 set to be updated
--> Processing Dependency: libXpm.so.4()(64bit) for package: gd-2.0.35-10.el6.x86_64
--> Processing Dependency: libX11.so.6()(64bit) for package: gd-2.0.35-10.el6.x86_64
---> Package krb5-devel.x86_64 0:1.8.2-3.el6_0.7 set to be updated
--> Processing Dependency: krb5-libs = 1.8.2-3.el6_0.7 for package: krb5-devel-1.8.2-3.el6_0.7.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.8.2-3.el6_0.7.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.8.2-3.el6_0.7.x86_64
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.8.2-3.el6_0.7.x86_64
---> Package libX11-devel.x86_64 0:1.3-2.el6 set to be updated
--> Processing Dependency: pkgconfig(xcb) >= 1.1.92 for package: libX11-devel-1.3-2.el6.x86_64
--> Processing Dependency: pkgconfig(xproto) for package: libX11-devel-1.3-2.el6.x86_64
--> Processing Dependency: libXau-devel for package: libX11-devel-1.3-2.el6.x86_64
--> Processing Dependency: pkgconfig(kbproto) for package: libX11-devel-1.3-2.el6.x86_64
--> Processing Dependency: pkgconfig(xcb) for package: libX11-devel-1.3-2.el6.x86_64
--> Processing Dependency: libXdmcp-devel for package: libX11-devel-1.3-2.el6.x86_64
---> Package libXpm-devel.x86_64 0:3.5.8-2.el6 set to be updated
--> Processing Dependency: libXext.so.6()(64bit) for package: libXpm-devel-3.5.8-2.el6.x86_64
--> Processing Dependency: libXt.so.6()(64bit) for package: libXpm-devel-3.5.8-2.el6.x86_64
---> Package libidn-devel.x86_64 0:1.18-2.el6 set to be updated
---> Package libjpeg.x86_64 0:6b-46.el6 set to be updated
---> Package libpng.x86_64 2:1.2.44-1.el6 set to be updated
---> Package openssl.x86_64 0:1.0.0-4.el6_0.2 set to be updated
---> Package zlib-devel.x86_64 0:1.2.3-25.el6 set to be updated
---> Package fontconfig.x86_64 0:2.8.0-3.el6 set to be updated
---> Package keyutils-libs-devel.x86_64 0:1.4-1.el6 set to be updated
---> Package krb5-libs.x86_64 0:1.8.2-3.el6_0.7 set to be updated
---> Package libX11.x86_64 0:1.3-2.el6 set to be updated
--> Processing Dependency: libX11-common = 1.3-2.el6 for package: libX11-1.3-2.el6.x86_64
--> Processing Dependency: libxcb.so.1()(64bit) for package: libX11-1.3-2.el6.x86_64
---> Package libXau-devel.x86_64 0:1.0.5-1.el6 set to be updated
--> Processing Dependency: libXau = 1.0.5-1.el6 for package: libXau-devel-1.0.5-1.el6.x86_64
--> Processing Dependency: libXau.so.6()(64bit) for package: libXau-devel-1.0.5-1.el6.x86_64
---> Package libXdmcp-devel.x86_64 0:1.0.3-1.el6 set to be updated
--> Processing Dependency: libXdmcp = 1.0.3-1.el6 for package: libXdmcp-devel-1.0.3-1.el6.x86_64
--> Processing Dependency: libXdmcp.so.6()(64bit) for package: libXdmcp-devel-1.0.3-1.el6.x86_64
---> Package libXext.x86_64 0:1.1-3.el6 set to be updated
---> Package libXpm.x86_64 0:3.5.8-2.el6 set to be updated
---> Package libXt.x86_64 0:1.0.7-1.el6 set to be updated
--> Processing Dependency: libICE.so.6()(64bit) for package: libXt-1.0.7-1.el6.x86_64
--> Processing Dependency: libSM.so.6()(64bit) for package: libXt-1.0.7-1.el6.x86_64
---> Package libcom_err-devel.x86_64 0:1.41.12-3.el6 set to be updated
---> Package libselinux-devel.x86_64 0:2.0.94-2.el6 set to be updated
--> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-2.el6.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-2.el6.x86_64
---> Package libxcb-devel.x86_64 0:1.5-1.el6 set to be updated
---> Package xorg-x11-proto-devel.noarch 0:7.4-35.el6 set to be updated
---> Package libICE.x86_64 0:1.0.6-1.el6 set to be updated
---> Package libSM.x86_64 0:1.1.0-7.1.el6 set to be updated
---> Package libX11-common.noarch 0:1.3-2.el6 set to be updated
---> Package libXau.x86_64 0:1.0.5-1.el6 set to be updated
---> Package libXdmcp.x86_64 0:1.0.3-1.el6 set to be updated
---> Package libsepol-devel.x86_64 0:2.0.41-3.el6 set to be updated
---> Package libxcb.x86_64 0:1.5-1.el6 set to be updated
Dependencies Resolved
 Package                  Arch       Version                  Repository   Size
Installing:
 freetype-devel           x86_64     2.3.11-6.el6_0.2         updates     363 k
 gd-devel                 x86_64     2.0.35-10.el6            base         78 k
 libcurl-devel            x86_64     7.19.7-16.el6            base        241 k
 libjpeg-devel            x86_64     6b-46.el6                base        100 k
 libpng-devel             x86_64     2:1.2.44-1.el6           base        111 k
 libxml2-devel            x86_64     2.7.6-1.el6              base        1.1 M
 ncurses-devel            x86_64     5.7-3.20090208.el6       base        642 k
 openssl-devel            x86_64     1.0.0-4.el6_0.2          updates     1.1 M
 patch                    x86_64     2.6-6.el6                base         90 k
Installing for dependencies:
 automake                 noarch     1.11.1-1.2.el6           base        550 k
 fontconfig               x86_64     2.8.0-3.el6              base        186 k
 fontconfig-devel         x86_64     2.8.0-3.el6              base        209 k
 freetype                 x86_64     2.3.11-6.el6_0.2         updates     359 k
 gd                       x86_64     2.0.35-10.el6            base        142 k
 keyutils-libs-devel      x86_64     1.4-1.el6                base         28 k
 krb5-devel               x86_64     1.8.2-3.el6_0.7          updates     1.2 M
 libICE                   x86_64     1.0.6-1.el6              base         53 k
 libSM                    x86_64     1.1.0-7.1.el6            base         26 k
 libX11                   x86_64     1.3-2.el6                base        582 k
 libX11-common            noarch     1.3-2.el6                base        188 k
 libX11-devel             x86_64     1.3-2.el6                base        1.0 M
 libXau                   x86_64     1.0.5-1.el6              base         22 k
 libXau-devel             x86_64     1.0.5-1.el6              base         13 k
 libXdmcp                 x86_64     1.0.3-1.el6              base         22 k
 libXdmcp-devel           x86_64     1.0.3-1.el6              base        9.6 k
 libXext                  x86_64     1.1-3.el6                base         33 k
 libXpm                   x86_64     3.5.8-2.el6              base         59 k
 libXpm-devel             x86_64     3.5.8-2.el6              base         33 k
 libXt                    x86_64     1.0.7-1.el6              base        174 k
 libcom_err-devel         x86_64     1.41.12-3.el6            base         29 k
 libidn-devel             x86_64     1.18-2.el6               base        137 k
 libjpeg                  x86_64     6b-46.el6                base        134 k
 libpng                   x86_64     2:1.2.44-1.el6           base        180 k
 libselinux-devel         x86_64     2.0.94-2.el6             base        135 k
 libsepol-devel           x86_64     2.0.41-3.el6             base         64 k
 libxcb                   x86_64     1.5-1.el6                base        100 k
 libxcb-devel             x86_64     1.5-1.el6                base        139 k
 xorg-x11-proto-devel     noarch     7.4-35.el6               base        250 k
 zlib-devel               x86_64     1.2.3-25.el6             base         43 k
Updating for dependencies:
 krb5-libs                x86_64     1.8.2-3.el6_0.7          updates     684 k
 openssl                  x86_64     1.0.0-4.el6_0.2          updates     1.4 M
Transaction Summary
Install      39 Package(s)
Upgrade       2 Package(s)
Total download size: 12 M
Downloading Packages:
(1/41): automake-1.11.1-1.2.el6.noarch.rpm               | 550 kB     00:01
(2/41): fontconfig-2.8.0-3.el6.x86_64.rpm                | 186 kB     00:00
(3/41): fontconfig-devel-2.8.0-3.el6.x86_64.rpm          | 209 kB     00:00
(4/41): freetype-2.3.11-6.el6_0.2.x86_64.rpm             | 359 kB     00:00
(5/41): freetype-devel-2.3.11-6.el6_0.2.x86_64.rpm       | 363 kB     00:00
(6/41): gd-2.0.35-10.el6.x86_64.rpm                      | 142 kB     00:00
(7/41): gd-devel-2.0.35-10.el6.x86_64.rpm                |  78 kB     00:00
(8/41): keyutils-libs-devel-1.4-1.el6.x86_64.rpm         |  28 kB     00:00
(9/41): krb5-devel-1.8.2-3.el6_0.7.x86_64.rpm            | 1.2 MB     00:03
(10/41): krb5-libs-1.8.2-3.el6_0.7.x86_64.rpm            | 684 kB     00:01
(11/41): libICE-1.0.6-1.el6.x86_64.rpm                   |  53 kB     00:00
(12/41): libSM-1.1.0-7.1.el6.x86_64.rpm                  |  26 kB     00:00
(13/41): libX11-1.3-2.el6.x86_64.rpm                     | 582 kB     00:01
(14/41): libX11-common-1.3-2.el6.noarch.rpm              | 188 kB     00:00
(15/41): libX11-devel-1.3-2.el6.x86_64.rpm               | 1.0 MB     00:02
(16/41): libXau-1.0.5-1.el6.x86_64.rpm                   |  22 kB     00:00
(17/41): libXau-devel-1.0.5-1.el6.x86_64.rpm             |  13 kB     00:00
(18/41): libXdmcp-1.0.3-1.el6.x86_64.rpm                 |  22 kB     00:00
(19/41): libXdmcp-devel-1.0.3-1.el6.x86_64.rpm           | 9.6 kB     00:00
(20/41): libXext-1.1-3.el6.x86_64.rpm                    |  33 kB     00:00
(21/41): libXpm-3.5.8-2.el6.x86_64.rpm                   |  59 kB     00:00
(22/41): libXpm-devel-3.5.8-2.el6.x86_64.rpm             |  33 kB     00:00
(23/41): libXt-1.0.7-1.el6.x86_64.rpm                    | 174 kB     00:00
(24/41): libcom_err-devel-1.41.12-3.el6.x86_64.rpm       |  29 kB     00:00
(25/41): libcurl-devel-7.19.7-16.el6.x86_64.rpm          | 241 kB     00:00
(26/41): libidn-devel-1.18-2.el6.x86_64.rpm              | 137 kB     00:00
(27/41): libjpeg-6b-46.el6.x86_64.rpm                    | 134 kB     00:00
(28/41): libjpeg-devel-6b-46.el6.x86_64.rpm              | 100 kB     00:00
(29/41): libpng-1.2.44-1.el6.x86_64.rpm                  | 180 kB     00:00
(30/41): libpng-devel-1.2.44-1.el6.x86_64.rpm            | 111 kB     00:00
(31/41): libselinux-devel-2.0.94-2.el6.x86_64.rpm        | 135 kB     00:00
(32/41): libsepol-devel-2.0.41-3.el6.x86_64.rpm          |  64 kB     00:00
(33/41): libxcb-1.5-1.el6.x86_64.rpm                     | 100 kB     00:00
(34/41): libxcb-devel-1.5-1.el6.x86_64.rpm               | 139 kB     00:00
(35/41): libxml2-devel-2.7.6-1.el6.x86_64.rpm            | 1.1 MB     00:02
(36/41): ncurses-devel-5.7-3.20090208.el6.x86_64.rpm     | 642 kB     00:01
(37/41): openssl-1.0.0-4.el6_0.2.x86_64.rpm              | 1.4 MB     00:03
(38/41): openssl-devel-1.0.0-4.el6_0.2.x86_64.rpm        | 1.1 MB     00:02
(39/41): patch-2.6-6.el6.x86_64.rpm                      |  90 kB     00:00
(40/41): xorg-x11-proto-devel-7.4-35.el6.noarch.rpm      | 250 kB     00:00
(41/41): zlib-devel-1.2.3-25.el6.x86_64.rpm              |  43 kB     00:00
Total                                           300 kB/s |  12 MB     00:40
warning: rpmts_HdrFromFdno: Header V3 RSA/SHA256 Signature, key ID c105b9de: NOKEY
updates/gpgkey                                           | 3.3 kB     00:00 ...
Importing GPG key 0xC105B9DE "CentOS-6 Key (CentOS 6 Official Signing Key) <centos-6-key@centos.org>" from /etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-6
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
  Installing     : freetype-2.3.11-6.el6_0.2.x86_64                        1/43
  Installing     : fontconfig-2.8.0-3.el6.x86_64                           2/43
  Installing     : 2:libpng-1.2.44-1.el6.x86_64                            3/43
  Installing     : libICE-1.0.6-1.el6.x86_64                               4/43
  Installing     : libjpeg-6b-46.el6.x86_64                                5/43
  Updating       : krb5-libs-1.8.2-3.el6_0.7.x86_64                        6/43
  Installing     : libXau-1.0.5-1.el6.x86_64                               7/43
  Installing     : zlib-devel-1.2.3-25.el6.x86_64                          8/43
  Installing     : xorg-x11-proto-devel-7.4-35.el6.noarch                  9/43
  Installing     : libxcb-1.5-1.el6.x86_64                                10/43
  Updating       : openssl-1.0.0-4.el6_0.2.x86_64                         11/43
  Installing     : libSM-1.1.0-7.1.el6.x86_64                             12/43
  Installing     : libXdmcp-1.0.3-1.el6.x86_64                            13/43
  Installing     : libXau-devel-1.0.5-1.el6.x86_64                        14/43
  Installing     : freetype-devel-2.3.11-6.el6_0.2.x86_64                 15/43
  Installing     : fontconfig-devel-2.8.0-3.el6.x86_64                    16/43
  Installing     : libxcb-devel-1.5-1.el6.x86_64                          17/43
  Installing     : libXdmcp-devel-1.0.3-1.el6.x86_64                      18/43
  Installing     : 2:libpng-devel-1.2.44-1.el6.x86_64                     19/43
  Installing     : libjpeg-devel-6b-46.el6.x86_64                         20/43
  Installing     : libcom_err-devel-1.41.12-3.el6.x86_64                  21/43
  Installing     : automake-1.11.1-1.2.el6.noarch                         22/43
  Installing     : libsepol-devel-2.0.41-3.el6.x86_64                     23/43
  Installing     : libselinux-devel-2.0.94-2.el6.x86_64                   24/43
  Installing     : libidn-devel-1.18-2.el6.x86_64                         25/43
  Installing     : keyutils-libs-devel-1.4-1.el6.x86_64                   26/43
  Installing     : krb5-devel-1.8.2-3.el6_0.7.x86_64                      27/43
  Installing     : libX11-common-1.3-2.el6.noarch                         28/43
  Installing     : libX11-1.3-2.el6.x86_64                                29/43
  Installing     : libXpm-3.5.8-2.el6.x86_64                              30/43
  Installing     : gd-2.0.35-10.el6.x86_64                                31/43
  Installing     : libXext-1.1-3.el6.x86_64                               32/43
  Installing     : libXt-1.0.7-1.el6.x86_64                               33/43
  Installing     : patch-2.6-6.el6.x86_64                                 34/43
  Installing     : libX11-devel-1.3-2.el6.x86_64                          35/43
  Installing     : libXpm-devel-3.5.8-2.el6.x86_64                        36/43
  Installing     : gd-devel-2.0.35-10.el6.x86_64                          37/43
  Installing     : openssl-devel-1.0.0-4.el6_0.2.x86_64                   38/43
  Installing     : libcurl-devel-7.19.7-16.el6.x86_64                     39/43
  Installing     : libxml2-devel-2.7.6-1.el6.x86_64                       40/43
  Installing     : ncurses-devel-5.7-3.20090208.el6.x86_64                41/43
  Cleanup        : openssl-1.0.0-4.el6.x86_64                             42/43
  Cleanup        : krb5-libs-1.8.2-3.el6.x86_64                           43/43
Installed:
Dependency Installed:
Dependency Updated:
  krb5-libs.x86_64 0:1.8.2-3.el6_0.7      openssl.x86_64 0:1.0.0-4.el6_0.2
Complete!
Select Install
        1 apache + php + mysql + zend + eAccelerator + vsftpd + phpmyadmin + wdcp
        2 nginx + php + mysql + zend + eAccelerator + vsftpd + phpmyadmin + wdcp
        3 don't install is now
Please Input 1,2,3: 2
--2011-09-19 13:03:00--  http://dl.wdlinux.cn:5180/rpms/mysql-5.1.55-1.x86_64.rpm
Resolving dl.wdlinux.cn... 113.105.167.213
Connecting to dl.wdlinux.cn|113.105.167.213|:5180... connected.
HTTP request sent, awaiting response... 200 OK
Length: 29457609 (28M) [text/plain]
Saving to: 鈓ysql-5.1.55-1.x86_64.rpm?
100%[======================================>] 29,457,609   415K/s   in 70s
2011-09-19 13:04:09 (414 KB/s) - 鈓ysql-5.1.55-1.x86_64.rpm鈙aved [29457609/29457609]
--2011-09-19 13:04:09--  http://dl.wdlinux.cn:5180/rpms/nginx-0.8.54-1.x86_64.rpm
Length: 254698 (249K) [text/plain]
Saving to: 鈔ginx-0.8.54-1.x86_64.rpm?
100%[======================================>] 254,698      403K/s   in 0.6s
2011-09-19 13:04:10 (403 KB/s) - 鈔ginx-0.8.54-1.x86_64.rpm鈙aved [254698/254698]
--2011-09-19 13:04:10--  http://dl.wdlinux.cn:5180/rpms/php_nginx-5.2.17-1.x86_64.rpm
Length: 8682353 (8.3M) [text/plain]
Saving to: 鈖hp_nginx-5.2.17-1.x86_64.rpm?
100%[======================================>] 8,682,353    416K/s   in 20s
2011-09-19 13:04:30 (415 KB/s) - 鈖hp_nginx-5.2.17-1.x86_64.rpm鈙aved [8682353/8682353]
--2011-09-19 13:04:30--  http://dl.wdlinux.cn:5180/rpms/vsftpd-2.3.4-1.x86_64.rpm
Length: 58539 (57K) [text/plain]
Saving to: 鈜sftpd-2.3.4-1.x86_64.rpm?
100%[======================================>] 58,539       379K/s   in 0.2s
2011-09-19 13:04:31 (379 KB/s) - 鈜sftpd-2.3.4-1.x86_64.rpm鈙aved [58539/58539]
--2011-09-19 13:04:31--  http://dl.wdlinux.cn:5180/rpms/wdcp-1.1-1.noarch.rpm
Length: 5573833 (5.3M) [text/plain]
Saving to: 鈝dcp-1.1-1.noarch.rpm?
[root@localhost ~]#
歡迎轉(zhuǎn)載,但請(qǐng)保留此信息
本文連接:http://ahbydz.com/old/node/973
使用源碼包安裝吧,可以可裝
使用源碼包安裝吧,可以可裝
我也是這個(gè)錯(cuò)誤,郁悶死了,去次機(jī)房重裝系統(tǒng)很麻煩,不曉得有
我也是這個(gè)錯(cuò)誤,郁悶死了,去次機(jī)房重裝系統(tǒng)很麻煩,不曉得有啥解決辦法不這個(gè)問題
我找打解決辦法了,就是要用源碼安裝包,編譯安裝,我用虛擬機(jī)
我找打解決辦法了,就是要用源碼安裝包,編譯安裝,我用虛擬機(jī)編譯安裝一次,基本都要一個(gè)多小時(shí),希望在服務(wù)器上裝的時(shí)候能快一些
關(guān)于WDLINUX
關(guān)于WDLINUX 5.6集成安裝版的問題搞定!
是因?yàn)槲倚陆ㄕ军c(diǎn)的重定向規(guī)則用的是APACHE的規(guī)則!
哈哈,NGINX的格式不一樣!~~
格式改過來之后!立馬搞定!現(xiàn)在速度杠杠的!~~~
哦,關(guān)于6.0的還是希望官方看一下到底是什么問題,我覺得是BUG
因?yàn)?.6和6.0包和庫不一樣,6.0的比較新,有一些不兼
因?yàn)?.6和6.0包和庫不一樣,6.0的比較新,有一些不兼容
用源碼安裝是正常的
