[求助] 安裝一直顯示這個(gè)錯(cuò)誤提示“Install Error: php configure err ” 在線等....
Resolving Dependencies
--> Running transaction check
---> Package libcap-devel.i386 0:1.10-26 set to be updated
---> Package ntp.i386 0:4.2.2p1-15.el5.centos.1 set to be updated
---> Package sendmail.i386 0:8.13.8-8.1.el5_7 set to be updated
--> Processing Conflict: qmail conflicts sendmail
qmail-1.03-1.5.15.i386 from installed has depsolving problems
  --> qmail conflicts with sendmail
Error: qmail conflicts with sendmail
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
                        package-cleanup --dupes
                        rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
lanmp.sh: line 116: ntpdate: command not found
installing php...
----Install Error: php configure err -----------
換Centos 6試試,如果還不行就安裝RPM版,低內(nèi)存編譯wd經(jīng)常出錯(cuò)
RPM版 這個(gè)試過了 亂碼也安裝的不成功
買空間時(shí)選擇Centos 5 這個(gè)系統(tǒng)我能自己重新安裝嗎
回復(fù) 5# deibupi
    VPS都有控制面板的,可以在控制面板重裝系統(tǒng)
回復(fù) 6# frisa
    哥們現(xiàn)在是沒有面版,有QQ嗎?給個(gè)QQ。眩焉狭囊幌
回復(fù) 6# frisa
   加我QQ也可以 185554812 謝謝了
解決了嗎?
五龍影視
