[求助] 登錄ssh,錯誤提示,怎么解決?
本帖最后由 喜歡眺望遠處 于 2013-9-20 21:15 編輯
登錄ssh,錯誤提示
: command not found
: command not found
: command not found
'bash: /etc/profile: line 11: syntax error near unexpected token `{
'bash: /etc/profile: line 11: `pathmunge(){
怎么解決?
  1. # /etc/profile
  2. # System wide environment and startup programs, for login setup
  3. # Functions and aliases go in /etc/bashrc
  4. # It's NOT a good idea to change this file unless you know what you
  5. # are doing. It's much better to create a custom.sh shell script in
  6. # /etc/profile.d/ to make custom changes to your environment, as this
  7. # will prevent the need for merging in future updates.
  8. pathmunge(){
  9.     case "{PATH}:" in
  10.         *:"$1":*)
  11.             ;;
  12.         *)
  13.             if [ "$2" = "after" ] ; then
  14.                 PATH=$PATH1
  15.             else
  16.                 PATH=$1PATH
  17.             fi
  18.     esac
  19. }
  20. if [ -x /usr/bin/id ]; then
  21.     if [ -z "$EUID" ]; then
  22.         # ksh workaround
  23.         EUID=`id -u`
  24.         UID=`id -ru`
  25.     fi
  26.     USER="`id -un`"
  27.     LOGNAME=$USER
  28.     MAIL="/var/spool/mail/$USER"
  29. fi
  30. # Path manipulation
  31. if [ "$EUID" = "0" ]; then
  32.     pathmunge /sbin
  33.     pathmunge /usr/sbin
  34.     pathmunge /usr/local/sbin
  35. else
  36.     pathmunge /usr/local/sbin after
  37.     pathmunge /usr/sbin after
  38.     pathmunge /sbin after
  39. fi
  40. HOSTNAME=`/bin/hostname 2>/dev/null`
  41. HISTSIZE=1000
  42. if [ "$HISTCONTROL" = "ignorespace" ] ; then
  43.     export HISTCONTROL=ignoreboth
  44. else
  45.     export HISTCONTROL=ignoredups
  46. fi
  47. export PATH USER LOGNAME MAIL HOSTNAME HISTSIZE HISTCONTROL
  48. # By default, we want umask to get set. This sets it for login shell
  49. # Current threshold for system reserved uid/gids is 200
  50. # You could check uidgid reservation validity in
  51. # /usr/share/doc/setup-*/uidgid file
  52. if [ $UID -gt 199 ] && [ "`id -gn`" = "`id -un`" ]; then
  53.     umask 002
  54. else
  55.     umask 022
  56. fi
  57. for i in /etc/profile.d/*.sh ; do
  58.     if [ -r "$i" ]; then
  59.         if [ "${-#*i}" != "$-" ]; then
  60.             . "$i"
  61.         else
  62.             . "$i" >/dev/null 2>&1
  63.         fi
  64.     fi
  65. done
  66. unset i
  67. unset pathmunge
  68. unset -f pathmungeunset MAILCHECK
復制代碼
有改過
/etc/profile
這個文件?
好像就在最后加過這個
但是去掉了 也沒用
好像就在最后加過這個
但是去掉了 也沒用
根據(jù)提示一個個修復試試
我不懂linux,你能給我一個剛裝好的 profile 文件內(nèi)容?
