[BUG反饋] 管理員幫忙看下這個是什么原因?qū)е碌腗YSQL關(guān)閉
211012 12:28:31 [Note] Plugin 'FEDERATED' is disabled.
211012 12:28:31 InnoDB: The InnoDB memory heap is disabled
211012 12:28:31 InnoDB: Mutexes and rw_locks use GCC atomic builtins
211012 12:28:31 InnoDB: Compressed tables use zlib 1.2.11
211012 12:28:31 InnoDB: Initializing buffer pool, size = 128.0M
211012 12:28:31 InnoDB: Completed initialization of buffer pool
211012 12:28:31 InnoDB: highest supported file format is Barracuda.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
211012 12:28:31  InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
211012 12:28:31  InnoDB: Waiting for the background threads to start
211012 12:28:32 InnoDB: 5.5.62 started; log sequence number 48824248
211012 12:28:32 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
211012 12:28:32 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
211012 12:28:32 [Note] Server socket created on IP: '0.0.0.0'.
211012 12:28:32 [Note] Event Scheduler: Loaded 0 events
211012 12:28:32 [Note] /www/wdlinux/mysql-5.5.62/bin/mysqld: ready for connections.
Version: '5.5.62'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
211012 12:28:54 [Note] Plugin 'FEDERATED' is disabled.
211012 12:28:54 InnoDB: The InnoDB memory heap is disabled
211012 12:28:54 InnoDB: Mutexes and rw_locks use GCC atomic builtins
211012 12:28:54 InnoDB: Compressed tables use zlib 1.2.11
211012 12:28:54 InnoDB: Initializing buffer pool, size = 128.0M
InnoDB: mmap(137363456 bytes) failed; errno 12
211012 12:28:54 InnoDB: Completed initialization of buffer pool
211012 12:28:54 InnoDB: Fatal error: cannot allocate memory for the buffer pool
211012 12:28:54 [ERROR] Plugin 'InnoDB' init function returned error.
211012 12:28:54 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
211012 12:28:54 [ERROR] Unknown/unsupported storage engine: InnoDB
211012 12:28:54 [ERROR] Aborting
211012 12:28:54 [Note] /www/wdlinux/mysql-5.5.62/bin/mysqld: Shutdown complete
云服務器每隔2天左右,mysql服務就會停止,需要手動啟動一下。上面是日志,幫忙看下,也希望能對你們改進wdcp有幫助。
應該是InnoDB的原因
