[求助] centos6.8版本安裝出錯(cuò)
configurations, phps install is complete
      visit http://ip:8080
      more infomation please visit http://ahbydz.com/bbs/
installing php...
make: *** No rule to make target `clean'.  Stop.
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for cc... cc
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether ln -s works... yes
checking for system library directory... lib
checking whether to enable runpaths... no
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for gawk... gawk
checking for bison... bison -y
checking for bison version... 2.4 (ok)
checking for re2c... re2c
checking for re2c version... 0.13.5 (ok)
checking whether to enable computed goto gcc extension with re2c... no
checking whether to force non-PIC code in shared modules... no
checking whether /dev/urandom exists... yes
checking for pthreads_cflags... -pthread
checking for pthreads_lib...
Configuring SAPI modules
checking for AOLserver support... no
checking for Apache 1.x module support via DSO through APXS... no
checking for Apache 1.x module support... no
checking whether to enable Apache charset compatibility option... no
checking for Apache 2.0 filter-module support via DSO through APXS... no
checking for Apache 2.0 handler-module support via DSO through APXS...
Sorry, I cannot run apxs.  Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /www/wdlinux/apache/bin/apxs follows:
./configure: line 8426: /www/wdlinux/apache/bin/apxs: No such file or directory
configure: error: Aborting
x86_64
CentOS release 6.8 (Final)
----Install Error: php configure err -----------
求解決,謝謝
niancong.com
