[求助] 老大,進(jìn)來看看!顯示升級(jí)mysql5.5成功,但是又顯示有錯(cuò)誤!重啟服務(wù)器后mysql沒起來
詳見以下:
Shutting down MySQL....... SUCCESS!
scripts/mysql_install_db.sh: line 325: @HOSTNAME@: command not found
WARNING: The host '' could not be looked up with resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MySQL version. The MySQL daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MySQL privileges !
Installing MySQL system tables...
130525 22:01:45 [ERROR] /www/wdlinux/mysql/bin/mysqld: unknown option '--skip-locking'
130525 22:01:45 [ERROR] Aborting
130525 22:01:45 [Note] /www/wdlinux/mysql/bin/mysqld: Shutdown complete
Installation of system tables failed!  Examine the logs in
/www/wdlinux/mysql/var for more information.
You can try to start the mysqld daemon with:
    shell> /www/wdlinux/mysql/bin/mysqld --skip-grant &
and use the command line tool /www/wdlinux/mysql/bin/mysql
to connect to the mysql database and look at the grant tables:
    shell> /www/wdlinux/mysql/bin/mysql -u root mysql
    mysql> show tables
Try 'mysqld --help' if you have problems with paths.  Using --log
gives you a log in /www/wdlinux/mysql/var that may be helpful.
Please consult the MySQL manual section
'Problems running mysql_install_db', and the manual section that
describes problems on your OS.  Another information source are the
MySQL email archives available at http://lists.mysql.com/.
Please check all of the above before mailing us!  And remember, if
you do mail us, you MUST use the /www/wdlinux/mysql/scripts/mysqlbug script!
ERROR! MySQL server PID file could not be found!
Starting MySQL.. ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.5.27/data/localhost.localdomain.pid).
Running..., Please Wait...
err
mysql update is OK
sanbao
用的是老大這個(gè)升級(jí)腳本
5#  發(fā)表于 2012-10-8 17:10 | 只看該作者
不用重新編譯面板
你可以用這個(gè)試試
wget http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh
sanbao
