[求助] 阿里云安裝wdcp總是httpd無法啟動(dòng),提示錯(cuò)誤
本帖最后由 yjl71951 于 2013-5-17 17:02 編輯
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root password 'new-password'
/www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root -h AY130511191303918964Z password 'new-password'
Alternatively you can run:
/www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default.  This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
Starting MySQL. SUCCESS!
Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
[FAILED]
Starting nginx: [  OK  ]
Starting httpd: Syntax error on line 232 of /www/wdlinux/wdapache/conf/httpd.conf:
Cannot load /www/wdlinux/wdapache/modules/libphp5.so into server: libpng12.so.0: cannot open shared object file: No such file or directory
[FAILED]
Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
============  lanmp_wdcp install OK  ==============
          configuration ,lamp or lnmp,wdcp install is finshed
          visit http://ip
          wdcp visit http://ip:8080
          more infomation please visit http://ahbydz.com
還沒有辦法訪問控制面板,大家賜教了。!急急急。≡诰等!
久愛優(yōu)惠
求大家給點(diǎn)指教,我安裝了不下五次了,每次都是這個(gè)錯(cuò)誤,不知道什么原因,搜索了半天也沒有好的解決辦法,拜請(qǐng)各位幫忙。!
久愛優(yōu)惠
輸入ip地址無法訪問控制面板,這是為什么啊
久愛優(yōu)惠
不知道這個(gè)方法能不能幫到你  http://ahbydz.com/bbs/thread-3869-1-1.html
應(yīng)該是yum更新沒成功,相關(guān)的包和庫,沒安裝好
yum更新沒成功,怎么解決,卸載重裝過N次了,一樣沒用。
菜鳥愛搞站
我遇到的錯(cuò)誤提示信息和你的網(wǎng)站也是一樣的,我的面板可以訪問,就是新建的網(wǎng)站訪問不了,都重裝了幾次還是這樣,頭痛……
SEO
回復(fù) 5# admin
    不是更新的事情,我好幾個(gè)不同機(jī)房的機(jī)器都出現(xiàn)這個(gè)問題,HTTPD啟動(dòng)不了,說是Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so,出問題的系統(tǒng)都是CENTOS 6.5 64位
我的也是centos 6.5 64位,也這樣,找了幾天,不得其解,誰給個(gè)提示
我的也一樣
怎么解決?
我的是centos6.6
UP UP 我也是,煩死了,在線等,CENTOS 6.5
-bash: servicen: command not found
[root@li541-104 ~]# service httpd restart
Stopping httpd:                                            [FAILED]
                                                           [FAILED]
裝了好多次,還是老樣子,有沒有個(gè)解決方法,真不想用這個(gè)核心的,但是現(xiàn)在VPS很多都是新版本的系統(tǒng)
前臺(tái)IP訪問如果只開APACHE,顯示無法連接,如果都開就是502,是最近才出現(xiàn)的問題嗎,注意是64位服務(wù)器
