[求助] 幫分析下mysql自動停止的原因
看網(wǎng)站統(tǒng)計應該是0點左右mysql無法訪問的  7.49我重啟的mysql服務
之前也有過一次我是重啟的機器
沒升3.2之前好好的,升完之后偶爾會出現(xiàn) 希望幫忙找出解決方法讓wdcp越做越好
170624  0:31:53 [Note] Plugin 'FEDERATED' is disabled.
170624  0:32:01 InnoDB: The InnoDB memory heap is disabled
170624  0:32:02 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170624  0:32:02 InnoDB: Compressed tables use zlib 1.2.3
170624  0:32:33 InnoDB: Initializing buffer pool, size = 128.0M
170624  0:50:18 InnoDB: Completed initialization of buffer pool
170624  7:49:43 [Note] Plugin 'FEDERATED' is disabled.
170624  7:49:43 InnoDB: The InnoDB memory heap is disabled
170624  7:49:43 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170624  7:49:43 InnoDB: Compressed tables use zlib 1.2.3
170624  7:49:43 InnoDB: Initializing buffer pool, size = 128.0M
170624  7:49:43 InnoDB: Completed initialization of buffer pool
170624  7:49:43 InnoDB: highest supported file format is Barracuda.
170624  7:49:43  InnoDB: Waiting for the background threads to start
170624  7:49:44 InnoDB: 5.5.54 started; log sequence number 1595675
170624  7:49:44 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
170624  7:49:44 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
170624  7:49:44 [Note] Server socket created on IP: '0.0.0.0'.
170624  7:49:44 [Note] Event Scheduler: Loaded 0 events
170624  7:49:44 [Note] /www/wdlinux/mysql-5.5.54/bin/mysqld: ready for connections.
Version: '5.5.54'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
我怎么感覺是靜安服務器原因,我銀盤總共才100G這個虛擬內(nèi)存就占100多
前幾天我靜安的一臺win系統(tǒng)也是這個問題
是單升級后臺還是環(huán)境也升級了?如果只升級了后臺wdcp是不會影響的
只有升級了mysql,apache這些,才可能和升級有關
也有可能是系統(tǒng)原因
