[求助] WDCP運(yùn)行一段時(shí)間后數(shù)據(jù)庫(kù)會(huì)掛掉到不到原因
每天都會(huì)出現(xiàn)數(shù)據(jù)庫(kù)掛掉,重啟又OK了,找不到原因,附上以下日志,望各老大能幫忙看看!謝謝了!
  • 操作系統(tǒng)CentOS 6.8 64位
  • CPU1核
  • 內(nèi)存1GB
  • 系統(tǒng)盤20GB(本地磁盤)
  • 公網(wǎng)帶寬1Mbps
當(dāng)前版本: wdCP v3.2.4
操作系統(tǒng):2.6.32-642.6.2.el6.x86_64
170518  0:39:03 [Warning] IP address '211.180.107.240' could not be resolved: Name or service not known
170518  0:57:20 [Warning] IP address '123.57.4.56' could not be resolved: Name or service not known
170518  1:13:39 [Warning] IP address '121.41.113.41' could not be resolved: Name or service not known
170518  1:44:35 [Warning] IP address '180.153.100.123' could not be resolved: Name or service not known
170518  2:26:36 [Warning] IP address '118.129.170.41' could not be resolved: Name or service not known
170518  2:33:49 [Warning] IP address '47.90.92.26' could not be resolved: Name or service not known
170518  3:56:22 [Warning] IP address '119.145.255.181' could not be resolved: Name or service not known
170518  5:08:29 [Warning] IP address '222.186.22.243' could not be resolved: Name or service not known
170518  5:15:12 [Warning] IP address '118.184.33.101' could not be resolved: Name or service not known
170518  6:15:35 [Warning] IP address '123.249.27.95' could not be resolved: Temporary failure in name resolution
170518  6:57:04 [Note] Plugin 'FEDERATED' is disabled.
170518  6:57:04 InnoDB: The InnoDB memory heap is disabled
170518  6:57:04 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170518  6:57:04 InnoDB: Compressed tables use zlib 1.2.3
170518  6:57:04 InnoDB: Initializing buffer pool, size = 128.0M
InnoDB: mmap(137363456 bytes) failed; errno 12
170518  6:57:04 InnoDB: Completed initialization of buffer pool
170518  6:57:04 InnoDB: Fatal error: cannot allocate memory for the buffer pool
170518  6:57:04 [ERROR] Plugin 'InnoDB' init function returned error.
170518  6:57:04 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
170518  6:57:04 [ERROR] Unknown/unsupported storage engine: InnoDB
170518  6:57:04 [ERROR] Aborting
170518  6:57:04 [Note] /www/wdlinux/mysql-5.5.54/bin/mysqld: Shutdown complete
170519 15:18:27 [Note] Plugin 'FEDERATED' is disabled.
170519 15:18:27 InnoDB: The InnoDB memory heap is disabled
170519 15:18:27 InnoDB: Mutexes and rw_locks use GCC atomic builtins
170519 15:18:27 InnoDB: Compressed tables use zlib 1.2.3
170519 15:18:27 InnoDB: Initializing buffer pool, size = 128.0M
170519 15:18:27 InnoDB: Completed initialization of buffer pool
170519 15:18:27 InnoDB: highest supported file format is Barracuda.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
170519 15:18:27  InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
InnoDB: Last MySQL binlog file position 0 507869, file name ./mysql-bin.000006
170519 15:18:28  InnoDB: Waiting for the background threads to start
170519 15:18:29 InnoDB: 5.5.54 started; log sequence number 60923990
170519 15:18:29 [Note] Recovering after a crash using mysql-bin
170519 15:18:29 [Note] Starting crash recovery...
170519 15:18:29 [Note] Crash recovery finished.
170519 15:18:29 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
170519 15:18:29 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
170519 15:18:29 [Note] Server socket created on IP: '0.0.0.0'.
170519 15:18:29 [Note] Event Scheduler: Loaded 0 events
170519 15:18:29 [Note] /www/wdlinux/mysql-5.5.54/bin/mysqld: ready for connections.
Version: '5.5.54-log'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
170519 18:33:35 [Warning] IP address '59.110.6.177' could not be resolved: Name or service not known
玩玩SEO
看像是有內(nèi)存溢出
  我的網(wǎng)站都沒(méi)有其它人訪問(wèn)的。就只有我一個(gè)人打開……有沒(méi)有辦法幫忙處理一下:handshake
玩玩SEO
刪除mysql  data下的 ib_logfile0、ib_logfile1這2個(gè)文件,然后啟動(dòng)MYSQL就好了。
我呀
回復(fù) 4# nong2106
   這個(gè)試過(guò)了,還是一樣過(guò)一段時(shí)間會(huì)卡死掉。
玩玩SEO
如果流量大的話 1G內(nèi)存是不是有點(diǎn)。
qiusongsong.net/dh/
回復(fù) 6# qiuss
   每天才2個(gè)獨(dú)立 IP,基本上都是自己在訪問(wèn)。流量很小的
玩玩SEO
解決了,應(yīng)該是WDCP和系統(tǒng)沖突導(dǎo)致的,換了另一家的LANP,運(yùn)行了一個(gè)星期都沒(méi)掛過(guò)
玩玩SEO
wdcp是不會(huì)和系統(tǒng)沖突的,就算會(huì),也不可能會(huì)影響到mysql這些WEB應(yīng)用環(huán)境
系統(tǒng)版本,mysql版本,以及相關(guān)設(shè)置或配置,則是有可能沖突的
我的也經(jīng)常出現(xiàn)這樣的問(wèn)題,數(shù)據(jù)庫(kù)一掛就得重啟,沒(méi)多長(zhǎng)時(shí)間就又掛掉,所有動(dòng)態(tài)程序包括后臺(tái)就打不開了。這個(gè)問(wèn)題一直沒(méi)解決。
懶。
前幾天重起的服務(wù)器,昨天數(shù)據(jù)庫(kù)又掛了,這個(gè)問(wèn)題一直有。一天也沒(méi)多少IP .
