[求助] 在線等,急 lanmp安裝失敗
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
•add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
•add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
•use the `-Wl,-rpath -Wl,LIBDIR' linker flag
•have your system administrator add LIBDIR to `/etc/ld.so.conf'
