[求助] 最近重裝wdcp的時候遇到502,,
%G                Welcome to CentOS
Starting udev: %G[  OK  ]
Setting hostname xianju:  [  OK  ]
Setting up Logical Volume Management:   1 logical volume(s) in volume group "Xvdbgroup" now active
  2 logical volume(s) in volume group "vg_501153278" now active
[  OK  ]
Checking filesystems
Checking all file systems.
[/sbin/fsck.ext4 (1) -- /] fsck.ext4 -a /dev/mapper/vg_501153278-lv_root
/dev/mapper/vg_501153278-lv_root: clean, 38415/558624 files, 330844/2230272 blocks
[/sbin/fsck.ext4 (1) -- /boot] fsck.ext4 -a /dev/xvda1
/dev/xvda1: clean, 56/128016 files, 101508/512000 blocks
[  OK  ]
Remounting root filesystem in read-write mode:  [  OK  ]
Mounting local filesystems:  [  OK  ]
Enabling /etc/fstab swaps:  [  OK  ]
Entering non-interactive startup
Starting monitoring for VG Xvdbgroup:   1 logical volume(s) in volume group "Xvdbgroup" monitored
[  OK  ]
Starting monitoring for VG vg_501153278:   2 logical volume(s) in volume group "vg_501153278" monitored
[  OK  ]
Bringing up loopback interface:  [  OK  ]
Bringing up interface eth0:  [  OK  ]
Starting auditd: [FAILED]
Starting system logger: [  OK  ]
Mounting xenfs on /proc/xen: [  OK  ]
Detecting Linux distribution version: [  OK  ]
Starting xe daemon:  [  OK  ]
Mounting other filesystems:  [  OK  ]
Retrigger failed udev events[  OK  ]
Starting sshd: [  OK  ]
Starting MySQL. SUCCESS!
Starting sendmail: [  OK  ]
Starting sm-client: [  OK  ]
Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
[FAILED]
Starting nginx: [  OK  ]
Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
Starting wdcp: [  OK  ]
Starting crond: [  OK  ]
resize2fs 1.41.12 (17-May-2010)
The filesystem is already 10457088 blocks long.  Nothing to do!
其中httpd 無法啟動 缺少libphp5.so 請問這個該怎么辦
