感謝!d感謝!d
沒(méi)有金幣呀金幣,如何是好
不錯(cuò)不錯(cuò)學(xué)習(xí)了
支持你喔讚讚讚讚
時(shí)發(fā)生大發(fā)發(fā)送方式是否
我試試。。。。。。。。。。!
echo hello
升級(jí) 一下試試啊
sh ./zendopcache_ins.sh
再下載一次試試。。。
謝謝分享謝謝分享謝謝分享
試一下
看看行不行
回復(fù) 1# 8l8
升級(jí)mysql5.6.28出現(xiàn)這個(gè)錯(cuò)誤,是什么緣故。。。
   -- Looking for asprintf-- Looking for asprintf - found
-- Check size of pthread_t
-- Check size of pthread_t - done
-- Using cmake version 2.8.12.2
-- Not building NDB
-- Performing Test HAVE_PEERCRED
-- Performing Test HAVE_PEERCRED - Success
-- Library mysqlclient depends on OSLIBS -lpthread;m;rt;dl
-- Googlemock was not found. gtest-based unit tests will be disabled. You can run cmake . -DENABLE_DOWNLOADS=1 to automatically download and build required components from source.
-- If you are inside a firewall, you may need to use an http proxy: export http_proxy=http://example.com:80
-- Library mysqlserver depends on OSLIBS -lpthread;m;rt;crypt;dl
-- CMAKE_BUILD_TYPE: RelWithDebInfo
-- COMPILE_DEFINITIONS: HAVE_CONFIG_H
-- CMAKE_C_FLAGS:  -Wall -Wextra -Wformat-security -Wvla -Wwrite-strings -Wdeclaration-after-statement
-- CMAKE_CXX_FLAGS:  -Wall -Wextra -Wformat-security -Wvla -Woverloaded-virtual -Wno-unused-parameter
-- CMAKE_C_FLAGS_RELWITHDEBINFO: -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF
-- CMAKE_CXX_FLAGS_RELWITHDEBINFO: -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF
-- Configuring incomplete, errors occurred!
See also "/root/mysql-5.6.28/CMakeFiles/CMakeOutput.log".
See also "/root/mysql-5.6.28/CMakeFiles/CMakeError.log".
configure err
看看啊啊啊
你好啊啊啊
回復(fù)一個(gè),下載文件
