[BUG反饋] lanmp_wdcp_v2.5快速安裝RPM包 安裝后無法連接mysql,
84 和 BudgetVM  centos 6 32bit 安裝完畢以后打開 后臺提示 無法連接mysql,請檢查mysql是否已啟動及用戶密碼是否設(shè)置正確!:
chown: invalid user: `mysql.mysql'
Starting MySQL. ERROR! Manager of pid-file quit without updating file.
/www/wdlinux/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)        '
Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mys        ql.sock' (2)
Starting httpd: [  OK  ]
Starting nginx: [  OK  ]
Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -        B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p2000        0:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
============  lanmp_wdcp install OK  ==============
          configuration ,lamp or lnmp,wdcp install is finshed
          visit http://ip
          wdcp visit http://ip:8080
          more infomation please visit http://ahbydz.com
mysql沒有安裝完整
執(zhí)行如下
  1. groupadd -g 27 mysql
  2. useradd -g 27 -u 27 -d /dev/null -s /sbin/nologin mysql
  3. chown -R mysql.mysql /www/wdlinux/mysql/var
再啟動
service mysqld restart
試試
同樣有這樣的問題,換成centos 5.X就好 了。
