[求助] 老大來(lái)看下,這個(gè)行不行,啟用nginx的fastcgi cache提高網(wǎng)站php訪(fǎng)問(wèn)速度
先看下測(cè)試數(shù)據(jù):
bin\ab.exe -n 100 -c 5 http://www.9enjoy.com
未使用
Concurrency Level:      5
Time taken for tests:   9.016 seconds
Complete requests:      100
Failed requests:        0
Write errors:           0
Total transferred:      1696500 bytes
HTML transferred:       1669000 bytes
Requests per second:    11.09 [#/sec] (mean)
Time per request:       450.781 [ms] (mean)
Time per request:       90.156 [ms] (mean, across all concurrent requests)
Transfer rate:          183.76 [Kbytes/sec] received
日志里顯示,頁(yè)面執(zhí)行需要0.004s
Time taken for tests:   3.203 seconds
Failed requests:        0
Write errors:           0
Total transferred:      1685400 bytes
Requests per second:    31.22 [#/sec] (mean)
Time per request:       160.156 [ms] (mean)
Time per request:       32.031 [ms] (mean, across all concurrent requests)
Transfer rate:          513.84 [Kbytes/sec] received
日志里顯示,頁(yè)面執(zhí)行時(shí)間為0s
提高的很明顯!
配置主要參考:http://www.fuchaoqun.com/2011/01/nginx-fastcgi_cache/
配置參數(shù):
http里:
fastcgi_cache_path /www/php_cache  levels=1:2  keys_zone=cache_php:30m inactive=1d max_size=10g;
server里:
    location ~ .*\.php?$
      #fastcgi_pass  unix:/tmp/php-cgi.sock;
      fastcgi_pass  127.0.0.1:9000;
      fastcgi_index index.php;
      include fcgi.conf;
      #以下是fastcgi_cache的配置
      fastcgi_cache   cache_php;
      fastcgi_cache_valid   200 302  1h;
      fastcgi_cache_min_uses  1;
      fastcgi_cache_use_stale error  timeout invalid_header http_500;
      fastcgi_cache_key $host$request_uri;
fastcgi_cache_path:fastcgi_cache緩存目錄,可以設(shè)置目錄層級(jí),比如1:2會(huì)生成16*256個(gè)字目錄,cache_php是這個(gè)緩存空間的名字,cache是用多少內(nèi)存(這樣熱門(mén)的內(nèi)容nginx直接放內(nèi)存,提高訪(fǎng)問(wèn)速度),inactive表示默認(rèn)失效時(shí)間,max_size表示最多用多少硬盤(pán)空間。本來(lái)還有個(gè)fastcgi_temp_path參數(shù),但發(fā)現(xiàn)似乎沒(méi)用。
fastcgi_cache_valid:定義哪些http頭要緩存
fastcgi_cache_min_uses:URL經(jīng)過(guò)多少次請(qǐng)求將被緩存
fastcgi_cache_use_stale:定義哪些情況下用過(guò)期緩存
fastcgi_cache_key:定義fastcgi_cache的key,示例中就以請(qǐng)求的URI作為緩存的key,Nginx會(huì)取這個(gè)key的md5作為緩存文件,如果設(shè)置了緩存哈希目錄,Nginx會(huì)從后往前取相應(yīng)的位數(shù)做為目錄
fastcgi_cache:用哪個(gè)緩存空間
指定刪除某一URL的php文件的緩存的PHP程序
大致代碼如下:
$md5 = md5($url);
    $cacheFile = '/www/php_cache/' . substr($md5, -1, 1) . '/' . substr($md5, -3, 2) . '/' . $md5;
    if (!file_exists($cacheFile)) {
        exit('緩存不存在。');
    if (@unlink($cacheFile)) {
        echo '清除緩存成功。';
    } else {
        echo '清除緩存失敗。';
再說(shuō)下,我用的是nginx+apache  模式,是不是對(duì)我來(lái)講不起作用??
