[求助] 日志發(fā)現(xiàn)可疑內(nèi)容,導(dǎo)致服務(wù)器會在這個(gè)時(shí)間內(nèi)無法打開網(wǎng)站
/var/log/cron內(nèi)容
  1. Apr  1 22:00:01 localhost CROND[8312]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  2. Apr  1 22:01:01 localhost CROND[8317]: (root) CMD (run-parts /etc/cron.hourly)
  3. Apr  1 22:01:01 localhost run-parts(/etc/cron.hourly)[8317]: starting 0anacron
  4. Apr  1 22:01:01 localhost anacron[8328]: Anacron started on 2012-04-01
  5. Apr  1 22:01:01 localhost anacron[8328]: Normal exit (0 jobs run)
  6. Apr  1 22:01:01 localhost run-parts(/etc/cron.hourly)[8330]: finished 0anacron
  7. Apr  1 22:10:01 localhost CROND[8346]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  8. Apr  1 22:20:01 localhost CROND[8365]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  9. Apr  1 22:30:01 localhost CROND[8384]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  10. Apr  1 22:40:01 localhost CROND[8404]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  11. Apr  1 22:50:01 localhost CROND[8423]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  12. Apr  1 23:00:01 localhost CROND[8452]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  13. Apr  1 23:01:01 localhost CROND[8473]: (root) CMD (run-parts /etc/cron.hourly)
  14. Apr  1 23:01:01 localhost run-parts(/etc/cron.hourly)[8473]: starting 0anacron
  15. Apr  1 23:01:01 localhost anacron[8483]: Anacron started on 2012-04-01
  16. Apr  1 23:01:01 localhost anacron[8483]: Normal exit (0 jobs run)
  17. Apr  1 23:01:01 localhost run-parts(/etc/cron.hourly)[8485]: finished 0anacron
  18. Apr  1 23:10:01 localhost CROND[8536]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  19. Apr  1 23:20:01 localhost CROND[8555]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  20. Apr  1 23:30:01 localhost CROND[8574]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  21. Apr  1 23:40:01 localhost CROND[8593]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  22. Apr  1 23:50:01 localhost CROND[8612]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  23. Apr  1 23:53:01 localhost CROND[8620]: (root) CMD (/usr/lib64/sa/sa2 -A)
  24. Apr  2 00:00:01 localhost CROND[8642]: (root) CMD (/usr/lib64/sa/sa1 -S DISK 1 1)
  25. Apr  2 00:01:01 localhost CROND[8647]: (root) CMD (run-parts /etc/cron.hourly)
  26. Apr  2 00:01:01 localhost run-parts(/etc/cron.hourly)[8647]: starting 0anacron
  27. Apr  2 00:01:01 localhost anacron[8658]: Anacron started on 2012-04-02
  28. Apr  2 00:01:01 localhost run-parts(/etc/cron.hourly)[8660]: finished 0anacron
  29. Apr  2 00:01:01 localhost anacron[8658]: Jobs will be executed sequentially
  30. Apr  2 00:01:01 localhost anacron[8658]: Normal exit (0 jobs run)
/var/log/secure的內(nèi)容:
  1. Apr  1 23:00:39 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  2. Apr  1 23:00:39 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
  3. Apr  1 23:00:55 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  4. Apr  1 23:00:55 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
  5. Apr  1 23:01:25 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  6. Apr  1 23:01:25 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
  7. Apr  1 23:01:43 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  8. Apr  1 23:01:43 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
  9. Apr  1 23:02:18 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  10. Apr  1 23:02:18 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sr.php
  11. Apr  1 23:02:18 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  12. Apr  1 23:02:18 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sr.php
  13. Apr  2 00:03:13 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  14. Apr  2 00:03:13 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
  15. Apr  2 00:03:26 localhost sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; COMMAND=/www/wdlinux/wdphp/bin/php
  16. Apr  2 00:03:26 localhost sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
不是太明白這兩個(gè)日志文件內(nèi)容,貼出來求助,執(zhí)行這個(gè)調(diào)度時(shí),網(wǎng)站會打不開。
不太明白你的意思
哪個(gè)時(shí)間段,執(zhí)行什么調(diào)度
上面兩個(gè)是正常的日志,沒看出有哪些異常
當(dāng)網(wǎng)站不穩(wěn)定,打不開的時(shí)候,我查了下日志,最新更新的日志文件就是上面說的兩個(gè),對應(yīng)上時(shí)間就是上面貼出來的內(nèi)容了,管理得意思是說間歇性不穩(wěn)定的情況跟環(huán)境無關(guān)是嗎?
這種問題很難回答吧!有時(shí)緩存文件清除之后也會使服務(wù)器附載突然升高
