老大,新建站點(diǎn),都是404錯(cuò)誤,配置文件生成了對(duì)應(yīng)的,目錄里也上傳了網(wǎng)站程序  但是就是404
沒(méi)有有80端口, 在 啟動(dòng)服務(wù) 也沒(méi)有nginxd或httpd,怎么辦?
zzzzzz
還是有些作用的。。。。按照步驟來(lái)。。。。
歲月靜好
回復(fù) 1# admin
    老大麻煩幫忙看看!
新建網(wǎng)站無(wú)法打開;
IP能訪問(wèn);
有.conf 文件;
public_html有內(nèi)容;
系統(tǒng)管理 》命令運(yùn)行 里執(zhí)行
service nginxd restart
service httpd restart
[root@localhost ~]# service nginxd restart
Stopping nginx: nginx: [warn] conflicting server name "cs.34mei.com" on 0.0.0.0:80, ignored
                                                           [  OK  ]
Shutting down php_fpm . done
Starting nginx: nginx: [warn] conflicting server name "cs.34mei.com" on 0.0.0.0:80, ignored
                                                           [  OK  ]
Starting php_fpm  done
[root@localhost ~]# service httpd restart
httpd: unrecognized service
[root@localhost ~]# service httpd start
httpd: 未被識(shí)別的服務(wù)
[root@localhost ~]# service nginxd start
nginxd: 未被識(shí)別的服務(wù)
[root@localhost ~]#
我是小眼森
回復(fù) 1# admin
   QQ截圖20160310202654.png 一開始安裝網(wǎng)站,連接數(shù)據(jù)庫(kù)的時(shí)候出現(xiàn)502,按照帖子所說(shuō)重啟服務(wù)器,重啟后就變成這個(gè)樣子了!
新建整站,每次都打不開
Stopping httpd:                                            [  OK  ]
Starting httpd: Syntax error on line 9 of /www/wdlinux/httpd-2.2.24/conf/vhost/00000.default.conf:
Invalid command 'php_admin_value', perhaps misspelled or defined by a module not included in the server configuration
                                                           [FAILED]
[root@localhost ~]#
Stopping httpd:                                            [FAILED]
Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
                                                           [FAILED]
我的也是這樣,求解
回復(fù) 28# marquis
    感謝分享
Restarting nginxd (via systemctl):  Job for nginxd.service failed because the control process exited with error code. See "systemctl status nginxd.service" and "journalctl -xe" for details.
                                                           [失敗]
提示重定向次數(shù)過(guò)多,網(wǎng)站無(wú)法打開怎么解決呢
回復(fù) 49# adokele
   我的情況跟你的一樣 裝的是nginx 突然創(chuàng)建網(wǎng)站無(wú)法訪問(wèn) 以前的網(wǎng)站還可以訪問(wèn) 請(qǐng)問(wèn)你是怎么解決的?
精彩每一天
wdcp的演示也打不開是為什么。安裝了V3.2.
