[求助] Install Error: mysql configure err 安不了
[root@AY140528162754239263Z ~]# sh install.sh
Setting up Install Process
No package screen available.
Nothing to do
Cannot find 'screen' command,install without screen(default yes)?
(Yes/No): yes
grep: /etc/redhat-release: No such file or directory
Select Install
    1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    4 install all service
    5 don't install is now
Please Input 1,2,3,4,5: 4
Select php version:
    1 php-5.2.17 (default)
    2 php-5.3.27
Please Input 1,2: 2
error: skipping http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm - transfer failed - Unknown or unexpected error
Retrieving http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm
No package gcc-c++ available.
No package autoconf available.
No package libtool-ltdl-devel available.
No package gd-devel available.
No package freetype-devel available.
No package libxml2-devel available.
No package libjpeg-devel available.
No package libpng-devel available.
No package openssl-devel available.
No package curl-devel available.
No package patch available.
No package libmcrypt-devel available.
No package libmhash-devel available.
No package ncurses-devel available.
No package libcap-devel available.
No package sendmail available.
No package unzip available.
Nothing to do
29 May 11:04:56 ntpdate[1541]: the NTP socket is in use, exiting
sed: can't read /etc/selinux/config: No such file or directory
installing mysql,this may take a few minutes,hold on plz...
configure in progress ...
Preparing...                ##################################################
rpmforge-release            ##################################################
Resolving Dependencies
--> Running transaction check
---> Package libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf set to be updated
--> Processing Dependency: libmcrypt = 2.5.7-1.2.el5.rf for package: libmcrypt-devel
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: libmcrypt-devel
---> Package mhash-devel.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Processing Dependency: mhash = 0.9.9-1.el5.rf for package: mhash-devel
--> Processing Dependency: libmhash.so.2()(64bit) for package: mhash-devel
---> Package libmcrypt.x86_64 0:2.5.7-1.2.el5.rf set to be updated
---> Package mhash.x86_64 0:0.9.9-1.el5.rf set to be updated
Dependencies Resolved
Package               Arch         Version                Repository      Size
Installing:
libmcrypt-devel       x86_64       2.5.7-1.2.el5.rf       rpmforge       112 k
mhash-devel           x86_64       0.9.9-1.el5.rf         rpmforge        19 k
Installing for dependencies:
libmcrypt             x86_64       2.5.7-1.2.el5.rf       rpmforge       182 k
mhash                 x86_64       0.9.9-1.el5.rf         rpmforge       161 k
Transaction Summary
Install       4 Package(s)
Upgrade       0 Package(s)
Total download size: 475 k
Downloading Packages:
Total                                           116 kB/s | 475 kB     00:04
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
  Installing     : mhash                                                    1/4
  Installing     : libmcrypt                                                2/4
  Installing     : mhash-devel                                              3/4
  Installing     : libmcrypt-devel                                          4/4
Installed:
  libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf mhash-devel.x86_64 0:0.9.9-1.el5.rf
Dependency Installed:
  libmcrypt.x86_64 0:2.5.7-1.2.el5.rf       mhash.x86_64 0:0.9.9-1.el5.rf
Complete!
29 May 11:06:00 ntpdate[7794]: the NTP socket is in use, exiting
我老是安裝在這兒,是Aliyun Linux 5.7 64位系統(tǒng),不要說去看教程,我安照教程說的按了無數(shù)遍還是不行,不知道這個(gè)安裝包怎么回事。
install error: mysql configure err解決方法
出現(xiàn)這個(gè)錯(cuò)誤是因?yàn)槟_本里面的環(huán)境由于未知的原因沒有裝上運(yùn)行以下兩行重新安裝即可
  1. yum install -y gcc cmake ncurses-devel
  2. rm -rf ./src/mysql*
回復(fù) 2# fox1383164k
    太感謝你了,你的回答解決了我的問題。
我裝的CENTOS 7.3,VPS 購買好,第一次安裝WDCP 3.2很順利,提示安裝成功,只是IP:8080 死活打不開,
解決不了,我就面板上重裝了系統(tǒng),結(jié)果不是這錯(cuò)誤就是那錯(cuò)誤,怎么就是安裝不了,
然后我又裝6.X的系統(tǒng),還是出錯(cuò),
然后又裝7.3
沒辦法了,仔細(xì)看錯(cuò)誤就是Install Error: mysql configure err
百度幾個(gè)答案都解決不了,
換你的就不提示這個(gè)錯(cuò)誤了,等下安裝完看能成功不。
2樓威武。。!
現(xiàn)在是2021年,我的系統(tǒng)是CentOS8 通過WDLinux集成安裝包下載LANMP出現(xiàn)了同樣的錯(cuò)誤,試過了以上方法還是不可以,需要幫助。
同問。新買的阿里云ecs,按其官方教程安裝wdcp,前半程都順利到了1,2,3,4,5,我選擇安裝1,然后就卡住了:
-Install Error: mysql configure err-
前后安裝兩遍都不行。安裝失敗。求同仁幫忙。
