無標題文檔
[發(fā)布] Nginx 1.4.2 穩(wěn)定版發(fā)布
輕量級web服務(wù)器Nginx發(fā)布最新穩(wěn)定版1.4.2。2013-07-17上個版本是2013-05-07的1.4.1,遺留穩(wěn)定版1.2.9/1.0.15/0.8.55。開發(fā)版本1.5.2。 完全改進:
Changes with nginx 1.4.2
17 Jul 2013
*) Bugfix: the $r->header_in() embedded perl method did not return value       of the "Cookie" and "X-Forwarded-For" request header lines; the bug       had appeared in 1.3.14.
*) Bugfix: nginx could not be built with the ngx_mail_ssl_module, but       without ngx_http_ssl_module; the bug had appeared in 1.3.14.
*) Bugfix: in the "proxy_set_body" directive.       Thanks to Lanshun Zhou.
*) Bugfix: the "fail_timeout" parameter of the "server" directive in the       "upstream" context might not work if "max_fails" parameter was used;       the bug had appeared in 1.3.0.
*) Bugfix: a segmentation fault might occur in a worker process if the       "ssl_stapling" directive was used.       Thanks to Piotr Sikora.
*) Bugfix: nginx/Windows might stop accepting connections if several       worker processes were used.
下載:http://nginx.org/download/nginx-1.4.2.tar.gz
msde.cn
好像不錯喔
老大將升級腳本發(fā)出來啊
懂我的
wdcp不用更新,更新nginx就可以
可以用
wget http://down.wdlinux.cn/in/nginx_up.sh
sh nginx_up.sh
就完了
默認是1.2.9版本,如想升級到其它的版本, 可在腳本后加上版本號,如
sh nginx_up.sh 1.4.1
就可以
我們最近經(jīng)常發(fā)現(xiàn)NGINX報502錯誤。希望NGINX的配置可以根據(jù)硬件情況自動優(yōu)化配置。
吃+玩+快樂
回復(fù) 5# 1600511920
http://ahbydz.com/bbs/viewthread.php?tid=1838&rpid=17861&ordertype=0&page=1#pid17861看這個
