無標題文檔
AI導航網(wǎng)AI應用網(wǎng)站大全 wdcp官方技術(shù)支持/服務 阿里云8折優(yōu)惠券 無敵云 騰訊云優(yōu)惠中,現(xiàn)注冊更有260代金額券贈送
2 做過哪些操作或改動設置等
[求助] eAccelerator0.9.6.1支持php5.4.26嗎?我怎么安裝失敗
eAccelerator0.9.6.1支持php5.4.26嗎?我怎么安裝失敗,求大神指教
eaccelerator-0.9.6.1/
eaccelerator-0.9.6.1/COPYING
eaccelerator-0.9.6.1/mm.h
eaccelerator-0.9.6.1/control.php
eaccelerator-0.9.6.1/AUTHORS
eaccelerator-0.9.6.1/doc/
eaccelerator-0.9.6.1/doc/php/
eaccelerator-0.9.6.1/doc/php/dasm.php
eaccelerator-0.9.6.1/doc/php/info.php
eaccelerator-0.9.6.1/doc/phpdoc.ini
eaccelerator-0.9.6.1/eaccelerator.c
eaccelerator-0.9.6.1/config.w32
eaccelerator-0.9.6.1/opcodes.c
eaccelerator-0.9.6.1/dasm.php
eaccelerator-0.9.6.1/eaccelerator.h
eaccelerator-0.9.6.1/ea_dasm.c
eaccelerator-0.9.6.1/NEWS
eaccelerator-0.9.6.1/mm.c
eaccelerator-0.9.6.1/ea_store.c
eaccelerator-0.9.6.1/eaccelerator.ini
eaccelerator-0.9.6.1/config.m4
eaccelerator-0.9.6.1/ea_restore.c
eaccelerator-0.9.6.1/debug.h
eaccelerator-0.9.6.1/bugreport.php
eaccelerator-0.9.6.1/ea_dasm.h
eaccelerator-0.9.6.1/README.win32
eaccelerator-0.9.6.1/opcodes.h
eaccelerator-0.9.6.1/ea_store.h
eaccelerator-0.9.6.1/ChangeLog
eaccelerator-0.9.6.1/fnmatch.h
eaccelerator-0.9.6.1/eaccelerator_version.h
eaccelerator-0.9.6.1/fnmatch.c
eaccelerator-0.9.6.1/Makefile.in
eaccelerator-0.9.6.1/ea_info.h
eaccelerator-0.9.6.1/.gitignore
eaccelerator-0.9.6.1/optimize.c
eaccelerator-0.9.6.1/debug.c
eaccelerator-0.9.6.1/PHP_Highlight.php
eaccelerator-0.9.6.1/ea_info.c
eaccelerator-0.9.6.1/win32/
eaccelerator-0.9.6.1/win32/eAccelerator.sln
eaccelerator-0.9.6.1/win32/eAccelerator.dsp
eaccelerator-0.9.6.1/win32/eAccelerator.vcproj
eaccelerator-0.9.6.1/win32/eAccelerator.dsw
eaccelerator-0.9.6.1/ea_restore.h
make: *** 沒有規(guī)則可以創(chuàng)建目標“clean”。 停止。
Configuring for:
PHP Api Version:         20100412
Zend Module Api No:      20100525
Zend Extension Api No:   220100525
configure: WARNING: unrecognized options: --with-eaccelerator-shared-memory
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for PHP prefix... /www/wdlinux/nginx_php-5.4.26
checking for PHP includes... -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/nginx_php-5.4.26/lib/php/extensions/no-debug-non-zts-20100525
checking for PHP installed headers prefix... /www/wdlinux/nginx_php-5.4.26/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable eaccelerator support... yes, shared
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking mandatory system headers... yes
checking whether union semun is defined in sys/sem.h... no
checking for sysvipc shared memory support... yes
checking for mmap shared memory support... yes
checking for mmap on /dev/zero shared memory support... yes
checking for anonymous mmap shared memory support... yes
checking for posix mmap shared memory support... no
checking for best shared memory type... sysvipc
checking for spinlock semaphores support... yes
checking for pthread semaphores support... yes
checking for posix semaphores support... no
checking for sysvipc semaphores support... yes
checking for fcntl semaphores support... yes
checking for flock semaphores support... yes
checking for best semaphores type... spinlock
checking for mprotect... yes
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
creating libtool
appending configuration tag "CXX" to libtool
configure: creating ./config.status
config.status: creating config.h
/bin/sh /tmp/2/eaccelerator-0.9.6.1/libtool --mode=compile cc  -I. -I/tmp/2/eaccelerator-0.9.6.1 -DPHP_ATOM_INC -I/tmp/2/eaccelerator-0.9.6.1/include -I/tmp/2/eaccelerator-0.9.6.1/main -I/tmp/2/eaccelerator-0.9.6.1 -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib  -DHAVE_CONFIG_H  -g -O2   -c /tmp/2/eaccelerator-0.9.6.1/eaccelerator.c -o eaccelerator.lo
mkdir .libs
cc -I. -I/tmp/2/eaccelerator-0.9.6.1 -DPHP_ATOM_INC -I/tmp/2/eaccelerator-0.9.6.1/include -I/tmp/2/eaccelerator-0.9.6.1/main -I/tmp/2/eaccelerator-0.9.6.1 -I/www/wdlinux/nginx_php-5.4.26/include/php -I/www/wdlinux/nginx_php-5.4.26/include/php/main -I/www/wdlinux/nginx_php-5.4.26/include/php/TSRM -I/www/wdlinux/nginx_php-5.4.26/include/php/Zend -I/www/wdlinux/nginx_php-5.4.26/include/php/ext -I/www/wdlinux/nginx_php-5.4.26/include/php/ext/date/lib -DHAVE_CONFIG_H -g -O2 -c /tmp/2/eaccelerator-0.9.6.1/eaccelerator.c  -fPIC -DPIC -o .libs/eaccelerator.o
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在函數(shù)‘eaccelerator_restore’中:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:878: 警告:賦值丟棄了指針目標類型的限定
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在函數(shù)‘eaccelerator_compile_file’中:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1317: 錯誤:‘zend_class_entry’沒有名為‘line_start’的成員
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c: 在文件層:
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1913: 錯誤:expected ‘=’, ‘,’, ‘;’, ‘a(chǎn)sm’ or ‘__attribute__’ before ‘eaccelerator_functions’
/tmp/2/eaccelerator-0.9.6.1/eaccelerator.c:1938: 錯誤:‘eaccelerator_functions’未聲明(不在函數(shù)內(nèi))
make: *** [eaccelerator.lo] 錯誤 1
make err
新劇場
我也是一樣的問題。。。
