標題: [求助] 1X升級時,不成功 [打印本頁]
作者: tianhuqiu    時間: 2011-12-24 05:12     標題: 1X升級時,不成功
還是虛擬機,系統(tǒng)為wdlinux_lnmp_32,只升級wdcp 1X為2.1版本
出現(xiàn)很多錯誤代碼,沒有升級成功,部分代碼如下:
  1. util.c: In function ‘a(chǎn)p_find_token’:
  2. util.c:1462: error: ‘test_char_table’ undeclared (first use in this function)
  3. util.c:1462: error: (Each undeclared identifier is reported only once
  4. util.c:1462: error: for each function it appears in.)
  5. util.c:1462: error: ‘T_HTTP_TOKEN_STOP’ undeclared (first use in this function)
  6. util.c: In function ‘a(chǎn)p_escape_shell_cmd’:
  7. util.c:1526: error: ‘test_char_table’ undeclared (first use in this function)
  8. util.c:1526: error: ‘T_ESCAPE_SHELL_CMD’ undeclared (first use in this function)
  9. util.c: In function ‘a(chǎn)p_escape_path_segment’:
  10. util.c:1711: error: ‘test_char_table’ undeclared (first use in this function)
  11. util.c:1711: error: ‘T_ESCAPE_PATH_SEGMENT’ undeclared (first use in this function)
  12. util.c: In function ‘a(chǎn)p_os_escape_path’:
  13. util.c:1740: error: ‘test_char_table’ undeclared (first use in this function)
  14. util.c:1740: error: ‘T_OS_ESCAPE_PATH’ undeclared (first use in this function)
  15. util.c: In function ‘a(chǎn)p_escape_logitem’:
  16. util.c:1811: error: ‘test_char_table’ undeclared (first use in this function)
  17. util.c:1811: error: ‘T_ESCAPE_LOGITEM’ undeclared (first use in this function)
  18. util.c: In function ‘a(chǎn)p_escape_errorlog_item’:
  19. util.c:1864: error: ‘test_char_table’ undeclared (first use in this function)
  20. util.c:1864: error: ‘T_ESCAPE_LOGITEM’ undeclared (first use in this function)
  21. make[2]: *** [util.lo] Error 1
  22. make[2]: Leaving directory `/mnt/usb/lanmp_last/lanmp/httpd-2.0.64/server'
  23. make[1]: *** [all-recursive] Error 1
  24. make[1]: Leaving directory `/mnt/usb/lanmp_last/lanmp/httpd-2.0.64/server'
  25. make: *** [all-recursive] Error 1
  26. ----Install Error: wdapache make err -----------
是不是升級時要停止某些服務(wù)?請指點,謝謝。
作者: admin    時間: 2011-12-24 12:34
VM還是其它虛擬機?確定是wdlinux_lnmp_32嗎
作者: tianhuqiu    時間: 2011-12-24 13:49
    VM
確定是那個版本
