標(biāo)題: [求助] 無(wú)法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確 [打印本頁(yè)]
作者: npcome    時(shí)間: 2014-4-9 13:40     標(biāo)題: 無(wú)法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確
wdcp后臺(tái)修改了mysql配置為InnoDB,mysql掛了,提示“無(wú)法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確”,admin的簽名試過(guò)沒(méi)用,論壇里說(shuō)的方法也用了,一樣沒(méi)用,錯(cuò)誤日志顯示:
140409 02:13:40 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
140409  2:13:41 [ERROR] Can't start server: Bind on TCP/IP port: Address already in use
140409  2:13:41 [ERROR] Do you already have another mysqld server running on port: 3306 ?
140409  2:13:41 [ERROR] Aborting
140409  2:13:41 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
