標(biāo)題: [BUG反饋] Warning: Unknown: open_basedir restriction in effect. [打印本頁]
作者: markeseo    時(shí)間: 2014-3-20 20:13     標(biāo)題: Warning: Unknown: open_basedir restriction in effect.
Warning: Unknown: open_basedir restriction in effect. File(/www/web/default/index.php) is not within the allowed path(s): (1) in Unknown on line 0
Warning: Unknown: failed to open stream: Operation not permitted in Unknown on line 0
Fatal error: Unknown: Failed opening required '/www/web/default/index.php' (include_path='.:/www/wdlinux/apache_php-5.2.17/lib/php') in Unknown on line 0
新建的出現(xiàn)這種,老網(wǎng)站沒有這是怎么回事?
默認(rèn)conf
<VirtualHost *:88>
DocumentRoot /www/web/default
</VirtualHost>
<Directory /www/web/default>
    Options FollowSymLinks
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
新建的
ErrorDocument 400 /errpage/400.html
ErrorDocument 403 /errpage/403.html
ErrorDocument 404 /errpage/404.html
ErrorDocument 405 /errpage/405.html
php_admin_value open_basedir /www/web/tveyshan:/tmp
<IfModule mod_deflate.c>
DeflateCompressionLevel 7
AddOutputFilterByType DEFLATE text/html text/plain text/xml application/x-httpd-php
AddOutputFilter DEFLATE css js html htm gif jpg png bmp php
</IfModule>
</VirtualHost>
<Directory /www/web/tveyshan>
    AllowOverride All
    Order allow,deny
    Allow from all
</Directory>
老的
php_admin_value open_basedir /www/web/ued361:/tmp
</IfModule>
</VirtualHost>
<Directory /www/web/ued361>
    AllowOverride All
    Order allow,deny
    Allow from all
</Directory>
