標題:
求教管理員,重新編譯MySQL要注意什么?
redmaozi
標題:
本帖最后由 redmaozi 于 2013-8-31 23:41 編輯
RT,需要給MySQL加入 分區(qū)特性,需要編譯的時候加入partition參數,
求教管理員內置的數據庫重新編譯的時候需要注意什么???
求管理員把configure參數給出,讓兄弟們少繞彎路!
一鍵包里不就有嗎
redmaozi
找到一段源碼:
# mysql install function
function mysql_ins {
local IN_LOG=$LOGPATH/${logpre}_mysql_install.log
echo
[ -f $mysql_inf ] && return
echo "installing mysql,this may take a few minutes,hold on plz..."
cd $IN_SRC
rm -fr mysql-$MYS_VER/
tar xf mysql-$MYS_VER.tar.gz >$IN_LOG 2>&1
if [ $OS_RL == 2 ]; then
if [ -f /usr/lib/x86_64-linux-gnu/libncurses.so ]; then
#LIBNCU="/usr/lib/x86_64-linux-gnu/libncurses.so"
LIBNCU=""
elif [ -f /usr/lib/i386-linux-gnu/libncurses.so ]; then
#LIBNCU="/usr/lib/i386-linux-gnu/libncurses.so"
LIBNCU=""
else
LIBNCU=""
fi
else
if [ -f /usr/lib64/libncursesw.so ]; then
LIBNCU="--with-named-curses-libs=/usr/lib64/libncursesw.so"
elif [ -f /usr/lib/libncursesw.so ]; then
LIBNCU="--with-named-curses-libs=/usr/lib/libncursesw.so"
else
LIBNCU=""
fi
fi
cd mysql-$MYS_VER/
make_clean
echo "configure in progress ..."
./configure --prefix=$IN_DIR/mysql-$MYS_VER \
--sysconfdir=$IN_DIR/etc \
--enable-assembler \
--enable-thread-safe-client \
--with-extra-charsets=complex \
--with-plugins=partition \
--with-ssl \
--with-embedded-server $LIBNCU >>$IN_LOG 2>&1
[ $? != 0 ] && err_exit "mysql configure err"
echo "make in progress ..."
make >>$IN_LOG 2>&1
[ $? != 0 ] && err_exit "mysql make err"
echo "make install in progress ..."
make install >>$IN_LOG 2>&1
[ $? != 0 ] && err_exit "mysql make install err"
ln -sf $IN_DIR/mysql-$MYS_VER $IN_DIR/mysql
[ -f /etc/my.cnf ] && mv /etc/my.cnf /etc/my.cnf.old
cp support-files/mysql.server $IN_DIR/init.d/mysqld
file_cp my.cnf $IN_DIR/etc/my.cnf
ln -sf $IN_DIR/etc/my.cnf /etc/my.cnf
$IN_DIR/mysql/bin/mysql_install_db >>$IN_LOG 2>&1
chown -R mysql.mysql $IN_DIR/mysql/var
chmod 755 $IN_DIR/init.d/mysqld
ln -sf $IN_DIR/init.d/mysqld /etc/init.d/mysqld
update-rc.d -f mysqld defaults >>$IN_LOG 2>&1
else
chkconfig --add mysqld >>$IN_LOG 2>&1
chkconfig --level 35 mysqld on >>$IN_LOG 2>&1
fi
ln -sf $IN_DIR/mysql/bin/mysql /bin/mysql
mkdir -p /var/lib/mysql
service mysqld start
echo "PATH=\$PATH:$IN_DIR/mysql/bin" > /etc/profile.d/mysql.sh
echo "$IN_DIR/mysql" > /etc/ld.so.conf.d/mysql-wdl.conf
ldconfig >>$IN_LOG 2>&1
$IN_DIR/mysql/bin/mysqladmin -u root password "wdlinux.cn"
/www/wdlinux/mysql/bin/mysql -uroot -p"wdlinux.cn" -e \
"use mysql;update user set password=password('wdlinux.cn') where user='root';
delete from user where user='';
DROP DATABASE test;
drop user ''@'%';flush privileges;"
ln -sf /tmp/mysql.sock /var/lib/mysql/
touch $mysql_inf
復制代碼
其中在編譯的時候添加如下參數就可以了!
jsrgsww
在lib/mysql.sh中添加這句話--with-plugins=partition \但是要重新安裝,怎么才能不重新安裝WDCP
