標(biāo)題: [求助] install Error: mysql configure err [打印本頁(yè)]
作者: liangkaihua    時(shí)間: 2013-8-26 22:27     標(biāo)題: install Error: mysql configure err
安裝的時(shí)候顯示install Error: mysql configure err,怎么都無(wú)法解決,系統(tǒng)時(shí)間正常,我的系統(tǒng)是centos 5.9 64位的,gcc也更新了,求幫助啊。rpm安裝也不成功。
信息如下:
Transaction Summary
Install     116 Package(s)
Upgrade       0 Package(s)
Total size: 69 M
Total download size: 395 k
Downloading Packages:
Total                                           374 kB/s | 395 kB     00:01
Running rpm_check_debug
ERROR with rpm_check_debug vs depsolve:
libfreetype.so.6()(64bit) is needed by freetype-devel-2.2.1-32.el5_9.1.x86_64
libltdl.so.3()(64bit) is needed by libtool-ltdl-devel-1.5.22-7.el5_4.x86_64
libXdmcp.so.6 is needed by libX11-1.0.3-11.el5_7.1.i386
libX11.so.6()(64bit) is needed by libXxf86vm-1.0.1-3.1.x86_64
libX11.so.6()(64bit) is needed by libX11-devel-1.0.3-11.el5_7.1.x86_64
libX11.so.6()(64bit) is needed by gd-2.0.33-9.4.el5_4.2.x86_64
libXpm.so.4()(64bit) is needed by gd-2.0.33-9.4.el5_4.2.x86_64
libfontconfig.so.1()(64bit) is needed by gd-2.0.33-9.4.el5_4.2.x86_64
libfreetype.so.6()(64bit) is needed by gd-2.0.33-9.4.el5_4.2.x86_64
libX11.so.6()(64bit) is needed by libXt-1.0.2-3.2.el5.x86_64
libfontconfig.so.1()(64bit) is needed by fontconfig-devel-2.4.1-7.el5.x86_64
libX11.so.6()(64bit) is needed by libXpm-devel-3.5.5-3.x86_64
libXpm.so.4()(64bit) is needed by libXpm-devel-3.5.5-3.x86_64
libX11.so.6()(64bit) is needed by libXext-1.0.1-2.1.x86_64
libXau.so.6()(64bit) is needed by libXext-1.0.1-2.1.x86_64
libX11.so.6()(64bit) is needed by mesa-libGL-6.5.1-7.11.el5_9.x86_64
libXau.so.6()(64bit) is needed by libXau-devel-1.0.1-3.1.x86_64
Complete!
(1, [u'Please report this error in http://bugs.centos.org/yum5bug'])
./lanmp.sh: line 116: ntpdate: command not found
sed: can't read /etc/selinux/config: No such file or directory
configure in progress ...
Preparing...                ##################################################
        package rpmforge-release-0.5.2-2.el5.rf.x86_64 is intended for a x86_64 architecture
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package autoconf.noarch 0:2.59-12 set to be updated
---> Package libXxf86vm.x86_64 0:1.0.1-3.1 set to be updated
---> Package libdrm.x86_64 0:2.0.2-1.1 set to be updated
Dependencies Resolved
Package                 Arch      Version                     Repository  Size
Installing:
autoconf                noarch    2.59-12                     base       647 k
bzip2                   x86_64    1.0.3-6.el5_5               base        50 k
curl-devel              i386      7.15.5-17.el5_9             updates    310 k
curl-devel              x86_64    7.15.5-17.el5_9             updates    318 k
freetype-devel          i386      2.2.1-32.el5_9.1            updates    149 k
freetype-devel          x86_64    2.2.1-32.el5_9.1            updates    149 k
gcc                     x86_64    4.1.2-54.el5                base       5.3 M
gcc-c++                 x86_64    4.1.2-54.el5                base       3.8 M
gd-devel                i386      2.0.33-9.4.el5_4.2          base        97 k
gd-devel                x86_64    2.0.33-9.4.el5_4.2          base       102 k
libcap-devel            i386      1.10-26                     base        16 k
libcap-devel            x86_64    1.10-26                     base        16 k
libjpeg-devel           i386      6b-37                       base       105 k
libjpeg-devel           x86_64    6b-37                       base       105 k
libmcrypt-devel         i386      2.5.7-5.el5                 epel       103 k
libmcrypt-devel         x86_64    2.5.8-4.el5.centos          extras      10 k
libpng-devel            i386      2:1.2.10-17.el5_8           base       182 k
libpng-devel            x86_64    2:1.2.10-17.el5_8           base       185 k
libtool-ltdl-devel      i386      1.5.22-7.el5_4              base        31 k
libtool-ltdl-devel      x86_64    1.5.22-7.el5_4              base        32 k
libxml2-devel           i386      2.6.26-2.1.21.el5_9.3       updates    2.1 M
libxml2-devel           x86_64    2.6.26-2.1.21.el5_9.3       updates    2.1 M
make                    x86_64    1:3.81-3.el5                base       470 k
openssl                 x86_64    0.9.8e-26.el5_9.1           updates    1.5 M
pam                     x86_64    0.99.6.2-12.el5             base       982 k
pkgconfig               x86_64    1:0.21-2.el5                base        61 k
readline                x86_64    5.1-3.el5                   base       228 k
xorg-x11-filesystem     noarch    7.1-2.fc6                   base       5.4 k
xorg-x11-proto-devel    x86_64    7.1-13.el5                  base       247 k
zlib                    x86_64    1.2.3-7.el5                 base        52 k
zlib-devel              x86_64    1.2.3-7.el5                 base       103 k
Transaction Summary
Install     110 Package(s)
Total size: 66 M
Complete!
./wdcp.sh: line 44: ntpdate: command not found
groupadd: group wdcpg exists
useradd: user wdcpu exists
作者: admin    時(shí)間: 2013-8-27 07:44
看下mysql的安裝日志
作者: liangkaihua    時(shí)間: 2013-8-27 08:38
管理員好,我我查看了/var/lib/mysql/user.err文件,里面是空的,不知道這個(gè)是不是安裝日志
作者: xmingle    時(shí)間: 2014-2-14 15:40
看了下日志
tar: mysql-5.1.72.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
lib/mysql.sh: line 32: ./configure: No such file or directory
好像沒(méi)mysql-5.1.72.tar.gz這個(gè)壓縮包
作者: sd788034    時(shí)間: 2014-2-14 16:45
同樣的問(wèn)題,之前裝了3個(gè)服務(wù)器沒(méi)有這個(gè)問(wèn)題,今天發(fā)生此問(wèn)題,日志和樓上兩位一樣……
作者: netcrsky    時(shí)間: 2014-10-2 06:37
好復(fù)雜。郁悶。復(fù)雜。
