標題: [求助] 之前centos6老服務器上裝的wdcp面板全掛了 [打印本頁]
作者: pyj2004    時間: 2023-10-17 10:03     標題: 之前centos6老服務器上裝的wdcp面板全掛了
一訪問面板就報一堆的錯,打不開
  1. [root@ebs-58426 ~]# service wdcp stop
  2. [root@ebs-58426 ~]# service wdcp start
  3. 正在啟動 wdcp:                                            [確定]
  4. [root@ebs-58426 ~]# 2023/10/17 09:53:39 3137 :8080
  5. ^C
  6. [root@ebs-58426 ~]# service wdcp status
  7. wdcp (pid 3137) 正在運行...
  8. [root@ebs-58426 ~]# service wdcp status
  9. wdcp (pid 3137) 正在運行...
  10. [root@ebs-58426 ~]# runtime: goroutine stack exceeds 1000000000-byte limit
  11. runtime: sp=0xc020660390 stack=[0xc020660000, 0xc040660000]
  12. fatal error: stack overflow
  13. runtime stack:
  14. runtime.throw({0xbdb7ec?, 0x12a7280?})
  15.         /usr/local/go/src/runtime/panic.go:992 +0x71
  16. runtime.newstack()
  17.         /usr/local/go/src/runtime/stack.go:1101 +0x5cc
  18. runtime.morestack()
  19.         /usr/local/go/src/runtime/asm_amd64.s:547 +0x8b
  20. goroutine 200 [running]:
  21. wdcp/src/libs.Getfilect({0xbdb886?, 0xe?})
  22.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/src/libs/fun.go:3 +0x37 fp=0xc0206603a0 sp=0xc020660398 pc=0x915097
  23. wdcp/src/libs.Getfilect({0xbdb886?, 0x0?})
  24.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/src/libs/fun.go:4 +0x1e fp=0xc0206603c0 sp=0xc0206603a0 pc=0x91507e
  25. wdcp/src/libs.Getfilect({0xbdb886?, 0x0?})
  26.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/src/libs/fun.go:4 +0x1e fp=0xc0206603e0 sp=0xc0206603c0 pc=0x91507e
  27. wdcp/src/libs.Getfilect({0xbdb886?, 0x0?})
  28.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/src/libs/fun.go:4 +0x1e fp=0xc020660400 sp=0xc0206603e0 pc=0x91507e
  29. wdcp/src/libs.Getfilect({0xbdb886?, 0x0?})
  30.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/src/libs/fun.go:4 +0x1e fp=0xc020660420 sp=0xc020660400 pc=0x91507e
  31. wdcp/src/libs.Getfilect({0xbdb886?, 0x0?})
  32. created by net/http.(*Server).Serve
  33.         /usr/local/go/src/net/http/server.go:3071 +0x4db
  34. goroutine 1 [chan receive]:
  35. github.com/astaxie/beego.(*App).Run(0xc000190410, {0x0, 0x0, 0xc0003072b8?})
  36.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/app.go:168 +0x6c5
  37. github.com/astaxie/beego.Run({0x0, 0x0, 0x0})
  38.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/beego.go:72 +0x126
  39. main.main()
  40.         /Users/sky/Downloads/Telegram Desktop/wdcp (2)/main.go:234 +0xf91
  41. goroutine 4 [select]:
  42. database/sql.(*DB).connectionOpener(0xc000185450, {0xce3e88, 0xc00018e680})
  43.         /usr/local/go/src/database/sql/sql.go:1226 +0x8d
  44. created by database/sql.OpenDB
  45.         /usr/local/go/src/database/sql/sql.go:794 +0x18d
  46. goroutine 34 [chan receive]:
  47. github.com/astaxie/beego/logs.(*fileLogWriter).dailyRotate(0xc0003e4480, {0xc000052fd0?, 0x4d060a?, 0x12ea860?})
  48.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/logs/file.go:237 +0x159
  49. created by github.com/astaxie/beego/logs.(*fileLogWriter).initFd
  50.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/logs/file.go:221 +0x205
  51. goroutine 20 [select]:
  52. github.com/robfig/cron.(*Cron).run(0xc0000a2000)
  53.         /Users/sky/go/pkg/mod/github.com/robfig/cron@v1.2.0/cron.go:191 +0x585
  54. created by github.com/robfig/cron.(*Cron).Start
  55.         /Users/sky/go/pkg/mod/github.com/robfig/cron@v1.2.0/cron.go:144 +0x65
  56. goroutine 73 [syscall]:
  57. os/signal.signal_recv()
  58.         /usr/local/go/src/runtime/sigqueue.go:151 +0x2f
  59. os/signal.loop()
  60.         /usr/local/go/src/os/signal/signal_unix.go:23 +0x19
  61. created by os/signal.Notify.func1.1
  62.         /usr/local/go/src/os/signal/signal.go:151 +0x2a
  63. goroutine 58 [IO wait]:
  64. internal/poll.runtime_pollWait(0x7fdb0f178d48, 0x72)
  65.         /usr/local/go/src/runtime/netpoll.go:302 +0x89
  66. internal/poll.(*pollDesc).wait(0xc000176400?, 0xc00063a311?, 0x0)
  67.         /usr/local/go/src/internal/poll/fd_poll_runtime.go:83 +0x32
  68. internal/poll.(*pollDesc).waitRead(...)
  69.         /usr/local/go/src/internal/poll/fd_poll_runtime.go:88
  70. internal/poll.(*FD).Read(0xc000176400, {0xc00063a311, 0x1, 0x1})
  71.         /usr/local/go/src/internal/poll/fd_unix.go:167 +0x25a
  72. net.(*netFD).Read(0xc000176400, {0xc00063a311?, 0x727846?, 0xc000276fc0?})
  73.         /usr/local/go/src/net/fd_posix.go:55 +0x29
  74. net.(*conn).Read(0xc000010750, {0xc00063a311?, 0xc000276fc0?, 0x0?})
  75.         /usr/local/go/src/net/net.go:183 +0x45
  76. net/http.(*connReader).backgroundRead(0xc00063a300)
  77.         /usr/local/go/src/net/http/server.go:672 +0x3f
  78. created by net/http.(*connReader).startBackgroundRead
  79.         /usr/local/go/src/net/http/server.go:668 +0xca
  80. goroutine 195 [IO wait]:
  81. internal/poll.runtime_pollWait(0x7fdb0f179018, 0x72)
  82.         /usr/local/go/src/runtime/netpoll.go:302 +0x89
  83. internal/poll.(*pollDesc).wait(0xc000177080?, 0xc000042a00?, 0x0)
  84.         /usr/local/go/src/internal/poll/fd_poll_runtime.go:83 +0x32
  85. internal/poll.(*pollDesc).waitRead(...)
  86.         /usr/local/go/src/internal/poll/fd_poll_runtime.go:88
  87. internal/poll.(*FD).Accept(0xc000177080)
  88.         /usr/local/go/src/internal/poll/fd_unix.go:614 +0x22c
  89. net.(*netFD).accept(0xc000177080)
  90.         /usr/local/go/src/net/fd_unix.go:172 +0x35
  91. net.(*TCPListener).accept(0xc0000a8138)
  92.         /usr/local/go/src/net/tcpsock_posix.go:139 +0x28
  93. net.(*TCPListener).Accept(0xc0000a8138)
  94.         /usr/local/go/src/net/tcpsock.go:288 +0x3d
  95. net/http.(*Server).Serve(0xc000188000, {0xce3730, 0xc0000a8138})
  96.         /usr/local/go/src/net/http/server.go:3039 +0x385
  97. github.com/astaxie/beego/grace.(*Server).Serve(0xc00054b590)
  98.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/grace/server.go:42 +0x88
  99. github.com/astaxie/beego/grace.(*Server).ListenAndServe(0xc00054b590)
  100.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/grace/server.go:82 +0x2a6
  101. github.com/astaxie/beego.(*App).Run.func2()
  102.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/app.go:161 +0xb2
  103. created by github.com/astaxie/beego.(*App).Run
  104.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/app.go:154 +0x6b9
  105. goroutine 196 [chan receive]:
  106. github.com/astaxie/beego/grace.(*Server).handleSignals(0xc00054b590)
  107.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/grace/server.go:245 +0xc5
  108. created by github.com/astaxie/beego/grace.(*Server).ListenAndServe
  109.         /Users/sky/go/pkg/mod/github.com/astaxie/beego@v1.12.1/grace/server.go:61 +0xb2
復制代碼
作者: wdcpDEV    時間: 2023-11-18 08:21
我們會進行測試之后修復
作者: pyj2004    時間: 2023-11-25 15:24
回復 2# wdcpDEV
    有個時間點嗎,那些老服務器基本上都癱瘓了無法管理
作者: loveaixing    時間: 2023-11-27 15:46
我的也掛 了,怎么辦啊
作者: xander    時間: 2023-12-15 15:52
我的也是,請問如何處理
作者: a-123321    時間: 2024-2-29 13:17
我的也是這個原因吧,用命令啟動成功后,馬上自動關了
作者: yangtao    時間: 2024-3-11 11:10
有解決方法了嗎
作者: yangtao    時間: 2024-3-23 13:29
wget http://down.wdlinux.cn/in/update_v3.sh
sh update_v3.sh
通過把面板恢復到v3.3.12版本解決了
作者: pyj2004    時間: 2024-4-13 14:11
回復 8# yangtao
回退版本,確實有用
