標(biāo)題: [求助] 3.4&3.3版都安裝不上,求解決方案。 [打印本頁(yè)]
作者: alexgao999    時(shí)間: 2023-8-11 10:06     標(biāo)題: 3.4&3.3版都安裝不上,求解決方案。
騰訊云服務(wù)器,重裝過centOS8、centOS6.9(之前順利安裝過的其他服務(wù)器版本)、tencentOS3,選裝過mysql8和mysql5.7(之前安裝過),均提示以下錯(cuò)誤:[ 99%] Built target mysqlslap
Scanning dependencies of target mysqltest
[ 99%] Building CXX object client/CMakeFiles/mysqltest.dir/mysqltest.cc.o
/root/src/mysql-5.5.62/client/mysqltest.cc: In function ‘char* re_eprint(int)’:
/root/src/mysql-5.5.62/client/mysqltest.cc:8091: 警告:未使用的變量‘len’
Linking CXX executable mysqltest
[ 99%] Built target mysqltest
[ 99%] Generating mysqlserver_depends.c
Scanning dependencies of target mysqlserver
[100%] Building C object libmysqld/CMakeFiles/mysqlserver.dir/mysqlserver_depends.c.o
Linking C static library libmysqld.a
/usr/bin/ar: creating /root/src/mysql-5.5.62/libmysqld/libmysqld.a
[100%] Built target mysqlserver
Scanning dependencies of target symlink_libmysqlclient_r.a
[100%] Generating libmysqlclient_r.a
[100%] Built target symlink_libmysqlclient_r.a
Scanning dependencies of target mysql_client_test_embedded
[100%] Building C object libmysqld/examples/CMakeFiles/mysql_client_test_embedded.dir/__/__/tests/mysql_client_test.c.o
[100%] Building CXX object sql/CMakeFiles/sql.dir/sql_builtin.cc.o
Linking CXX static library libsql.a
[100%] Built target sql
Scanning dependencies of target mysql_embedded
[100%] Building CXX object libmysqld/examples/CMakeFiles/mysql_embedded.dir/__/__/client/completion_hash.cc.o
[100%] Building CXX object libmysqld/examples/CMakeFiles/mysql_embedded.dir/__/__/client/mysql.cc.o
[100%] Building CXX object libmysqld/examples/CMakeFiles/mysql_embedded.dir/__/__/client/readline.cc.o
Linking CXX executable mysql_embedded
Linking CXX executable mysql_client_test_embedded
^Cmake[2]: *** 正在刪除文件“l(fā)ibmysqld/examples/mysql_client_test_embedded”
make[2]: *** [libmysqld/examples/mysql_client_test_embedded] 中斷
make[2]: *** 正在刪除文件“l(fā)ibmysqld/examples/mysql_embedded”
make[2]: *** wait: 沒有子進(jìn)程。 停止。
make[2]: *** 正在等待未完成的任務(wù)....
make[1]: *** [libmysqld/examples/CMakeFiles/mysql_client_test_embedded.dir/all] 中斷
make[1]: *** [libmysqld/examples/CMakeFiles/mysql_embedded.dir/all] 錯(cuò)誤 2
make: *** wait: 沒有子進(jìn)程。 停止。
make: *** 正在等待未完成的任務(wù)....
x86_64
CentOS release 6.9 (Final)
作者: yunjiutian    時(shí)間: 2023-9-1 13:18
我測(cè)試安裝也是這個(gè)錯(cuò)誤。
應(yīng)該問題還多
作者: newlemon    時(shí)間: 2023-9-19 15:05
壓根不支持centos8,想在8上面安裝就根據(jù)提示錯(cuò)誤提示,自己加載編譯安裝需要的庫(kù)或文件。支持6版本系統(tǒng)
作者: wdcpDEV    時(shí)間: 2023-9-24 11:19
問題原因以及查明。預(yù)計(jì)明天進(jìn)行腳本更新。
作者: wdcpDEV    時(shí)間: 2023-9-24 23:25
新版本已經(jīng)上傳完成,建議使用Centos7.9   切勿使用6.9。6.9的內(nèi)核版本過于陳舊。無(wú)法安裝部分功能的依賴源。
