標題: [求助] 最新阿里云centos安裝多版本PHP無法啟動 [打印本頁]
作者: pkkgu    時間: 2021-2-21 08:47     標題: 最新阿里云centos安裝多版本PHP無法啟動
[root@aaaaaa-001 php-fpm.d]# /www/wdlinux/phps/73/bin/php-fpm start
Starting php-fpm [21-Feb-2021 09:50:16] ERROR: No pool defined. at least one pool section must be specified in config file
[21-Feb-2021 09:50:16] ERROR: failed to post process the configuration
[21-Feb-2021 09:50:16] ERROR: FPM initialization failed
failed
centos7.2到8.0都試了,都不行
作者: 看今朝    時間: 2021-2-22 15:52
Generating phar.php
Generating phar.phar
PEAR package PHP_Archive not installed: generated phar will require PHP's phar extension be enabled.
clicommand.inc
pharcommand.inc
invertedregexiterator.inc
directorygraphiterator.inc
directorytreeiterator.inc
phar.inc
Build complete.
Installing shared extensions:     /www/wdlinux/phps/72/lib/php/extensions/no-debug-non-zts-20170718/
Installing PHP CLI binary:        /www/wdlinux/phps/72/bin/
Installing PHP CLI man page:      /www/wdlinux/phps/72/php/man/man1/
Installing PHP FPM binary:        /www/wdlinux/phps/72/sbin/
Installing PHP FPM defconfig:     /www/wdlinux/phps/72/etc/
Installing PHP FPM man page:      /www/wdlinux/phps/72/php/man/man8/
Installing PHP FPM status page:   /www/wdlinux/phps/72/php/php/fpm/
Installing phpdbg binary:         /www/wdlinux/phps/72/bin/
Installing phpdbg man page:       /www/wdlinux/phps/72/php/man/man1/
Installing PHP CGI binary:        /www/wdlinux/phps/72/bin/
Installing PHP CGI man page:      /www/wdlinux/phps/72/php/man/man1/
Installing build environment:     /www/wdlinux/phps/72/lib/php/build/
Installing header files:          /www/wdlinux/phps/72/include/php/
Installing helper programs:       /www/wdlinux/phps/72/bin/
  program: phpize
  program: php-config
Installing man pages:             /www/wdlinux/phps/72/php/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /www/wdlinux/phps/72/lib/php/
[PEAR] Archive_Tar    - installed: 1.4.8
[PEAR] Console_Getopt - installed: 1.4.3
[PEAR] Structures_Graph- installed: 1.1.1
[PEAR] XML_Util       - installed: 1.4.3
[PEAR] PEAR           - installed: 1.10.10
Wrote PEAR system config file at: /www/wdlinux/phps/72/etc/pear.conf
You may want to add: /www/wdlinux/phps/72/lib/php to your php.ini include_path
//src/php-7.2.26/build/shtool install -c ext/phar/phar.phar /www/wdlinux/phps/72/bin
ln -s -f phar.phar /www/wdlinux/phps/72/bin/phar
Installing PDO headers:           /www/wdlinux/phps/72/include/php/ext/pdo/
--2021-02-22 16:50:22--  http://ahbydz.com/conf/php/php-fpm.conf
Resolving ahbydz.com (ahbydz.com)... 119.146.223.143
Connecting to ahbydz.com (ahbydz.com)|119.146.223.143|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://ahbydz.com/conf/php/php-fpm.conf [following]
Connecting to ahbydz.com (ahbydz.com)|119.146.223.143|:443... connected.
ERROR: cannot verify ahbydz.com's certificate, issued by ‘/C=US/O=Let's Encrypt/CN=R3’:
  Unable to locally verify the issuer's authority.
To connect to ahbydz.com insecurely, use `--no-check-certificate'.
7.2.26 install complete
同樣的安裝完php7.2后不能啟動
