標(biāo)題: [求助] 將php版本從5.4升級(jí)到7.2后,網(wǎng)站出現(xiàn)testing 123.。 [打印本頁]
作者: zhouh    時(shí)間: 2019-5-11 16:59     標(biāo)題: 將php版本從5.4升級(jí)到7.2后,網(wǎng)站出現(xiàn)testing 123.。
This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page it means that this site is working properly. This server is powered by CentOS.
網(wǎng)站就顯示這樣,百度了下,也沒有什么人解決。求助論壇大佬。。。
