標(biāo)題: [提問(wèn)] WDCP 到底能不能徹底解決 MYSQL自動(dòng)關(guān)閉問(wèn)題呢? [打印本頁(yè)]
作者: w1983912    時(shí)間: 2019-1-21 15:56     標(biāo)題: WDCP 到底能不能徹底解決 MYSQL自動(dòng)關(guān)閉問(wèn)題呢?
真的很奇怪啊,我不知道是阿里云故意攻擊還是怎么回事,10分鐘也就100多M緩存,我設(shè)置了定時(shí)任務(wù)10分鐘清理一次緩存,結(jié)果7小時(shí)后,今天早上7點(diǎn)半MYSQL 又掛了。
服務(wù)器是 1G內(nèi)存 1核  一天也就幾百I(mǎi)P,  以前512M的云服務(wù)器一天2萬(wàn)流量都沒(méi)出過(guò)MYSQL掛B的事情,搞不明白到底怎么了。
190121  7:24:43 [Note] Plugin 'FEDERATED' is disabled.
190121  7:24:43 InnoDB: The InnoDB memory heap is disabled
190121  7:24:43 InnoDB: Mutexes and rw_locks use GCC atomic builtins
190121  7:24:43 InnoDB: Compressed tables use zlib 1.2.7
190121  7:24:43 InnoDB: Initializing buffer pool, size = 128.0M InnoDB: mmap(137363456 bytes) failed; errno 12
190121  7:24:43 InnoDB: Completed initialization of buffer pool
190121  7:24:43 InnoDB: Fatal error: cannot allocate memory for the buffer pool
190121  7:24:43 [ERROR] Plugin 'InnoDB' init function returned error.
190121  7:24:43 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
190121  7:24:43 [ERROR] Unknown/unsupported storage engine: InnoDB
190121  7:24:43 [ERROR] Aborting
190121  7:24:43 [Note] /www/wdlinux/mysql-5.5.58/bin/mysqld: Shutdown complete
剛設(shè)置了
# mysql conf /etc/my.cnf
# Created by http://ahbydz.com
# Last Updated 2010.06.01
[client]
port                = 3306
socket                = /tmp/mysql.sock
[mysqld]
port                = 3306
skip-external-locking
key_buffer_size = 128M
innodb_buffer_pool_size = 64M          -------------這行是新增加的
max_allowed_packet = 1M
table_open_cache = 256
sort_buffer_size = 1M
read_buffer_size = 1M
read_rnd_buffer_size = 2M
myisam_sort_buffer_size = 8M
thread_cache_size = 8
query_cache_size= 16M
thread_concurrency = 8
max_connections = 300
wait_timeout = 30
interactive_timeout = 30
max_connect_errors = 9
long_query_time = 1
tmp_table_size = 16M
#log-bin=mysql-bin
#binlog_format=mixed
#server-id        = 1
[mysqldump]
quick
max_allowed_packet = 8M
[mysql]
no-auto-rehash
[myisamchk]
key_buffer_size = 12M
read_buffer = 1M
write_buffer = 1M
[mysqlhotcopy]
interactive-timeout
innodb_buffer_pool_size = 8M (安裝MySQL5.6到小于1G內(nèi)存服務(wù)器上,啟動(dòng)MySQL會(huì)失敗,報(bào)內(nèi)存分配失敗的錯(cuò)誤,此時(shí),需要修改my.cnf的內(nèi)存大小從標(biāo)準(zhǔn)128M設(shè)置到8M或者64M)
說(shuō)是還要加虛擬內(nèi)存,我記得2015年WD面板里好像有啟用虛擬內(nèi)存的,現(xiàn)在居然沒(méi)有這個(gè)虛擬內(nèi)存了
不知道該怎么辦?對(duì)于數(shù)據(jù)庫(kù)自動(dòng)關(guān)閉,WD是不是可以想幾個(gè)辦法來(lái)解決呢?
比如 做一個(gè)自動(dòng)檢測(cè)開(kāi)關(guān)給大家選擇  MYSQL無(wú)法連接則重啟服務(wù)器或重啟MYSQL。
技術(shù)能解答一下么?謝謝
作者: admin    時(shí)間: 2019-1-23 15:30
看這個(gè)錯(cuò)誤,是內(nèi)存問(wèn)題了
用innodb是要比較大內(nèi)存的
虛擬內(nèi)存,這個(gè)是操作系統(tǒng)的問(wèn)題,不是wdcp啟不啟用的問(wèn)題
作者: free166    時(shí)間: 2019-4-10 08:39
原來(lái)你也這樣啊,升級(jí)為wdCP v3.3.6以后這個(gè)MYSQL沒(méi)幾天內(nèi)存就不夠了,和你的一樣沒(méi)昨天就掛了,重啟服務(wù)器就好了,沒(méi)升級(jí)前沒(méi)事,你解決了嗎,這個(gè)MYSQL怎么優(yōu)化
作者: itohok    時(shí)間: 2019-4-19 14:29
回復(fù) 3# free166
扎心了,老鐵們,我的也是這樣。手欠點(diǎn)了下升級(jí)。昨天掛了一次,剛才又掛了,還重啟不了mysql,配置跟LZ一樣也是阿里云1G內(nèi)存
作者: kenkenms    時(shí)間: 2019-4-25 13:10
我的也是一樣的問(wèn)題,一天下來(lái)就掛了MySQL
作者: bydxxg    時(shí)間: 2019-4-28 10:16
我的今天也死了一次, 重起MYSQL才可以。
作者: 砍柴郎    時(shí)間: 2019-9-24 10:33
這個(gè)問(wèn)題大家想到了點(diǎn)什么辦法嗎?我的也是用的阿里云學(xué)生輕量那款,IP很少,一天幾十IP,也是經(jīng)常性MYSQL連不上,需要重啟mysqld,好麻煩。
作者: xuxus    時(shí)間: 2019-9-28 07:30
看來(lái)這個(gè)問(wèn)題很普遍!
機(jī)器用的不順心吶
