正在解析主機(jī) down.wdlinux.cn... 119.146.223.143
正在連接 down.wdlinux.cn|119.146.223.143|:80... 已連接。
已發(fā)出 HTTP 請求,正在等待回應(yīng)... 416 Requested Range Not Satisfiable
文件已下載完成;不會(huì)進(jìn)行任何操作。
[root@123 ~]# chmod 755 mysqli_ins.sh
[root@123 ~]# ./mysqli_ins.sh
Configuring for:
PHP Api Version: 20041225
Zend Module Api No: 20060613作者: 0215 時(shí)間: 2013-6-29 06:49
Zend Extension Api No: 220060519
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes作者: 0215 時(shí)間: 2013-6-29 06:49
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for PHP prefix... /www/wdlinux/apache_php-5.2.17
checking for PHP includes... -I/www/wdlinux/apache_php-5.2.17/include/php -I/www /wdlinux/apache_php-5.2.17/include/php/main -I/www/wdlinux/apache_php-5.2.17/inc lude/php/TSRM -I/www/wdlinux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/a pache_php-5.2.17/include/php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ex t/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.2.17/lib/php/e xtensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.2.17/incl ude/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking for MySQLi support... yes, shared
checking whether to enable embedded MySQLi support... no
checking for mysql_set_server_option in -lmysqlclient... yes
checking for mysql_stmt_field_count in -lmysqlclient... yes
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 1966080
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... no
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libra ries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
