標(biāo)題: [求助] 升級(jí)PHP5.3.17后 date出現(xiàn)錯(cuò)誤提示 [打印本頁(yè)]
作者: 問(wèn)題用戶    時(shí)間: 2013-6-22 14:46     標(biāo)題: 升級(jí)PHP5.3.17后 date出現(xiàn)錯(cuò)誤提示
本帖最后由 問(wèn)題用戶 于 2013-6-22 14:48 編輯
查看phpinfo的時(shí)候出現(xiàn)如下提示
  1. Warning: phpinfo(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Chongqing' for 'CST/8.0/no DST' instead in /www/web/basa/public_html/phpinfo.php on line 2
【升級(jí)方法】
http://ahbydz.com/bbs/thread-3737-1-1.html
  1. # wget http://down.wdlinux.cn/in/php_up53.sh
  2. # sh php_up53.sh
圖片附件: 剪貼板3.jpg (2013-6-22 14:41, 46.3 KB) / 下載次數(shù) 7309
http://ahbydz.com/bbs/attachment.php?aid=3120&k=453f353f537613799dd88cb4a4c588d0&t=1749406235&sid=7bq6NN
作者: itxx    時(shí)間: 2013-6-23 10:03
應(yīng)該是需要在php.ini中指定個(gè)默認(rèn)時(shí)區(qū)
作者: 問(wèn)題用戶    時(shí)間: 2013-6-23 11:28
謝謝版主,修改后確實(shí)好了
