Alternatively you can run:
/www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default. This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
Starting MySQL. SUCCESS! Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
[FAILED]
Starting nginx: [ OK ]
Starting httpd: Syntax error on line 232 of /www/wdlinux/wdapache/conf/httpd.conf:
Cannot load /www/wdlinux/wdapache/modules/libphp5.so into server: libpng12.so.0: cannot open shared object file: No such file or directory
[FAILED]
Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
============ lanmp_wdcp install OK ==============
configuration ,lamp or lnmp,wdcp install is finshed
visit http://ip
wdcp visit http://ip:8080
more infomation please visit http://ahbydz.com
UP UP 我也是,煩死了,在線等,CENTOS 6.5
-bash: servicen: command not found
[root@li541-104 ~]# service httpd restart
Stopping httpd: [FAILED]
[FAILED]作者: tinkleviselo 時間: 2016-11-9 21:34
這個錯誤:::Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
[FAILED]
是因為 沒有安裝庫文件 mhash mhash-devel 安裝好在試試。 我的已經(jīng)好了作者: weaho 時間: 2017-2-17 13:56
