[發(fā)布]
1.X版本的安裝下載
2011-12-9 12:04
1.X版本的安裝下載
1.X版本的安裝下載,目前只提供RPM包的安裝了,源碼包的安裝,只有2.X了
wget
http://dl.wdlinux.cn:5180/rpms/rpm_install_1x
sh rpm_install
然后可選安裝lamp 或 lnmp
即開始安裝,5分鐘左右
卸載只需執(zhí)行
sh rpm_install un
更多可看
http://ahbydz.com/wdcp_20110423
2013-7-22 00:13
sh rpm_install這一步,然后就出問題,好像提示找不到目錄了
chikwong
2013-12-28 00:27
2#
136162168
sh rpm_install_1x
2014-8-30 14:01
請問這個(gè)是用在那個(gè)系統(tǒng)環(huán)境下安裝的?
2014-8-31 11:20
============ mysql install OK ==============
error: Failed dependencies:
libcrypto.so.6 is needed by httpd-2.2.17-1.i386
libexpat.so.0 is needed by httpd-2.2.17-1.i386
libssl.so.6 is needed by httpd-2.2.17-1.i386
============ apache install error =============
