升級/全新安裝V3.2后,thinkphp5新增加的模塊總是無法訪問
潮音古韻
本帖最后由 潮音古韻 于 2017-6-25 17:04 編輯
提示:模塊不存在:index
我本地測試所有代碼正常,傳上linux服務(wù)器后就模塊不存在,但原先添加好的thinkphp5的應(yīng)用、模塊倒是能正常訪問,就是新上傳、新增加的總是提示模塊不存在。我昨天在購買的另一臺阿里云 centos7.3測試也是一樣,
另,在這臺新購買的,全新安裝wdcp3后,安裝php多版本時,安裝到5.6時總是出錯
錯誤信息為:
Thank you for using PHP.
config.status: creating php5.spec
config.status: creating main/build-defs.h
config.status: creating scripts/phpize
config.status: creating scripts/man1/phpize.1
config.status: creating scripts/php-config
config.status: creating scripts/man1/php-config.1
config.status: creating sapi/cli/php.1
config.status: creating sapi/fpm/php-fpm.conf
config.status: creating sapi/fpm/init.d.php-fpm
config.status: creating sapi/fpm/php-fpm.service
config.status: creating sapi/fpm/php-fpm.8
config.status: creating sapi/fpm/status.html
config.status: creating sapi/cgi/php-cgi.1
config.status: creating ext/phar/phar.1
config.status: creating ext/phar/phar.phar.1
config.status: creating main/php_config.h
config.status: executing default commands
/bin/sh /root/src/php-5.6.30/libtool --silent --preserve-dup-deps --mode=compile cc -Iext/standard/ -I/root/src/php-5.6.30/ext/standard/ -DPHP_ATOM_INC -I/root/src/php-5.6.30/include -I/root/src/php-5.6.30/main -I/root/src/php-5.6.30 -I/root/src/php-5.6.30/ext/date/lib -I/root/src/php-5.6.30/ext/ereg/regex -I/usr/include/libxml2 -I/usr/include/freetype2 -I/root/src/php-5.6.30/ext/mbstring/oniguruma -I/root/src/php-5.6.30/ext/mbstring/libmbfl -I/root/src/php-5.6.30/ext/mbstring/libmbfl/mbfl -I/root/src/php-5.6.30/ext/sqlite3/libsqlite -I/root/src/php-5.6.30/ext/zip/lib -I/root/src/php-5.6.30/TSRM -I/root/src/php-5.6.30/Zend -I/usr/include -g -O2 -fvisibility=hidden -c /root/src/php-5.6.30/ext/standard/html.c -o ext/standard/html.lo
env: cc: Permission denied
make: *** [ext/standard/html.lo] Error 1
x86_64
CentOS Linux release 7.3.1611 (Core)
----Install Error: 5.6.30 -----------
系統(tǒng)安裝了其它的安全防護(hù)軟件
潮音古韻
回復(fù)
2#
嗯嗯,在wdcp后臺安裝了云鎖
先卸載或停止云鎖,再安裝
