標(biāo)題: [求助] 安裝的時候包錯,提示 configure: error: SSL modules require the OpenSSL library. [打印本頁]
作者: guoyunpeng    時間: 2017-6-5 15:07     標(biāo)題: 安裝的時候包錯,提示 configure: error: SSL modules require the OpenSSL library.
  1. ./configure: error: SSL modules require the OpenSSL library.
  2. You can either do not enable the modules, or install the OpenSSL library
  3. into the system, or build the OpenSSL library statically from the source
  4. with nginx by using --with-openssl=<path> option.
  1. [root@iZ8vb9r1ibjyfl8o7x04taZ lanmp]# rpm -qa | grep openssl
  2. openssl-libs-1.0.1e-60.el7_3.1.x86_64
  3. openssl-1.0.1e-60.el7_3.1.x86_64
  4. [root@iZ8vb9r1ibjyfl8o7x04taZ lanmp]# openssl version
  5. OpenSSL 1.0.1e-fips 11 Feb 2013
openssl 已經(jīng)安裝了,怎么解決啊
x86_64
CentOS Linux release 7.2.1511 (Core)
----Install Error: nginx configure err -----------
作者: admin    時間: 2017-6-5 16:52
重新編譯安裝下openssl試試
