標(biāo)題: [求助] 安裝wdcpV3遇到下面這種情況,怎么解決? [打印本頁(yè)]
作者: 左手上陣    時(shí)間: 2017-5-20 10:42     標(biāo)題: 安裝wdcpV3遇到下面這種情況,怎么解決?
./configure: error: SSL modules require the OpenSSL library.
You can either do not enable the modules, or install the OpenSSL library
into the system, or build the OpenSSL library statically from the source
with nginx by using --with-openssl=<path> option.
x86_64
CentOS Linux release 7.3.1611 (Core)
----Install Error: nginx configure err -----------
我確認(rèn)OPEN SSL是已經(jīng)安裝了的
[root@jdu4e00u53f7 ~]# openssl version
OpenSSL 1.1.0b  26 Sep 2016
有沒(méi)有人遇到這種情況?怎么解決的?
作者: 左手上陣    時(shí)間: 2017-5-20 10:43
補(bǔ)充  系統(tǒng)版本
Linux jdu4e00u53f7 3.10.0-514.el7.x86_64 #1 SMP Tue Nov 22 16:42:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
作者: admin    時(shí)間: 2017-5-20 21:56
yum install -y openssl-devel
升級(jí)編譯升級(jí)openssl,并指定openssl的路徑再編譯PHP
