標(biāo)題: [求助] 一個php異步,在服務(wù)器上,得不到支持,發(fā)出來看一下! [打印本頁]
作者: else    時間: 2016-12-7 13:35     標(biāo)題: 一個php異步,在服務(wù)器上,得不到支持,發(fā)出來看一下!
  1. function request_by_fsockopen($url,$post_data=array()){
  2.     global  $config;
  3.     if(!strstr($url, 'http://'))
  4.     {
  5.         $url="http://" . $_SERVER['SERVER_NAME'] .$url;
  6.     }
  7.     $url_array      = parse_url($url);
  8.     $hostname       = $url_array['host'];
  9.     $port           = isset($url_array['port'])? $url_array['port'] : 80;
  10.     $requestPath    = $url_array['path'] ."?". $url_array['query'];
  11.     $fp = fsockopen($hostname, $port, $errno, $errstr, 30);
  12.     if (!$fp) {
  13.         echo "$errstr ($errno)";
  14.         return false;
  15.     }
  16.     $method = "GET";
  17.     if(!empty($post_data)){
  18.         $method = "POST";
  19.     }
  20.
  21.     $header = "$method $requestPath HTTP/1.1\r\n";
  22.     $header.="Host: ". $_SERVER['SERVER_NAME']."\r\n";
  23.     if(!empty($post_data)){
  24.         $_post = strval(NULL);
  25.         foreach($post_data as $k => $v){
  26.                 $_post[]= $k."=".urlencode($v);                                 //必須做url轉(zhuǎn)碼以防模擬post提交的數(shù)據(jù)中有&符而導(dǎo)致post參數(shù)鍵值對紊亂
  27.         }
  28.         $_post = implode('&', $_post);
  29.         $header .= "Content-Type: application/x-www-form-urlencoded\r\n";       //POST數(shù)據(jù)
  30.         $header .= "Content-Length: ". strlen($_post) ."\r\n";                  //POST數(shù)據(jù)的長度
  31.         $header .= "Referer: http://".$_SERVER['SERVER_NAME']."/function.php\r\n";           //構(gòu)造參數(shù),防止外步提交!
  32.         $header .= "AppKey: ". $config['appkey'] ."\r\n";
  33.
  34.         $header.="Connection: Close\r\n\r\n";//長連接關(guān)閉
  35.         $header .= $_post; //傳遞POST數(shù)據(jù)
  36.     }else{
  37.         $header.="Connection: Close\r\n\r\n";//長連接關(guān)閉
  38.     }
  39.     fwrite($fp, $header);
  40.
  41.     //-----------------調(diào)試代碼區(qū)間-----------------
  42.    /*$html = '';
  43.     while (!feof($fp)) {
  44.         $html.=fgets($fp);
  45.     }
  46.     echo $html;*/
  47.     //-----------------調(diào)試代碼區(qū)間-----------------
  48.     fclose($fp);
  49. }
