標題: [求助] 安裝一鍵安裝包lanmp_v3.1問題 啟動不了 服務(wù) [打印本頁]
作者: anyihw    時間: 2016-10-18 14:17     標題: 安裝一鍵安裝包lanmp_v3.1問題 啟動不了 服務(wù)
[root@localhost ~]# service httpd restart
Restarting httpd (via systemctl):  Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
                                                           [澶辮觸]
[root@localhost ~]# systemctl status httpd.service
?httpd.service - SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI.
   Loaded: loaded (/etc/rc.d/init.d/httpd)
   Active: failed (Result: exit-code) since 浜 2016-10-18 13:56:11 CST; 22s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 2880 ExecStart=/etc/rc.d/init.d/httpd start (code=exited, status=1/FAILURE)
10?18 13:56:11 localhost.localdomain systemd[1]: Starting SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI....
10?18 13:56:11 localhost.localdomain httpd[2880]: Starting httpd: AH00543: httpd: bad user name www
10?18 13:56:11 localhost.localdomain httpd[2880]: [澶辮觸]
10?18 13:56:11 localhost.localdomain systemd[1]: httpd.service: control process exited, code=exited status=1
10?18 13:56:11 localhost.localdomain systemd[1]: Failed to start SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI..
10?18 13:56:11 localhost.localdomain systemd[1]: Unit httpd.service entered failed state.
10?18 13:56:11 localhost.localdomain systemd[1]: httpd.service failed.
[root@localhost ~]# journalctl -xe
-- The start-up result is done.
10?18 13:55:01 localhost.localdomain systemd[1]: Starting Session 4 of user pcp.
-- Subject: Unit session-4.scope has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit session-4.scope has begun starting up.
10?18 13:55:01 localhost.localdomain CROND[2492]: (pcp) CMD ( /usr/libexec/pcp/bin/pmlogger_check -C)
10?18 13:55:03 localhost.localdomain systemd[1]: Removed slice user-995.slice.
-- Subject: Unit user-995.slice has finished shutting down
-- Unit user-995.slice has finished shutting down.
10?18 13:55:03 localhost.localdomain systemd[1]: Stopping user-995.slice.
-- Subject: Unit user-995.slice has begun shutting down
-- Unit user-995.slice has begun shutting down.
10?18 13:56:11 localhost.localdomain polkitd[969]: Registered Authentication Agent for unix-process:2875:107927 (system bus name :1.30 [/usr/bin/pkttyagent --notify-fd 5
-- Subject: Unit httpd.service has begun start-up
-- Unit httpd.service has begun starting up.
-- Subject: Unit httpd.service has failed
-- Unit httpd.service has failed.
-- The result is failed.
作者: ksxmu    時間: 2016-10-28 19:49
我也這個錯誤,解決不了
