標(biāo)題: [求助] centos 6.5 yum 出錯了 No module named sqlite [打印本頁]
作者: linlance    時間: 2016-10-11 20:04     標(biāo)題: centos 6.5 yum 出錯了 No module named sqlite
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.6.6 (r266:84292, Jul 23 2015, 15:22:56)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-11)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://yum.baseurl.org/wiki/Faq
兩臺機(jī)器都這樣,則么解決?
