centos 7 x64使用最新的wdcp然后mysql會(huì)自己關(guān)閉
d87904488
2016-5-18 19:55
網(wǎng)站用著用著數(shù)據(jù)庫就自動(dòng)關(guān)閉了我先把錯(cuò)誤代碼貼出了
160518 16:29:49 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.5.48/data
160518 16:29:49 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
160518 16:29:49 [Note] /www/wdlinux/mysql-5.5.48/bin/mysqld (mysqld 5.5.48) starting as process 25559 ...
160518 16:29:49 [Note] Plugin 'FEDERATED' is disabled.
160518 16:29:49 InnoDB: The InnoDB memory heap is disabled
160518 16:29:49 InnoDB: Mutexes and rw_locks use GCC atomic builtins
160518 16:29:49 InnoDB: Compressed tables use zlib 1.2.7
160518 16:29:49 InnoDB: Initializing buffer pool, size = 100.0M
160518 16:29:49 InnoDB: Completed initialization of buffer pool
160518 16:29:50 InnoDB: highest supported file format is Barracuda.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
160518 16:29:50 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
160518 16:29:50 InnoDB: Waiting for the background threads to start
160518 16:29:51 InnoDB: 5.5.48 started; log sequence number 1670874
160518 16:29:51 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
160518 16:29:51 [Note] - '0.0.0.0' resolves to '0.0.0.0';
160518 16:29:51 [Note] Server socket created on IP: '0.0.0.0'.
160518 16:29:51 [Note] Event Scheduler: Loaded 0 events
160518 16:29:51 [Note] /www/wdlinux/mysql-5.5.48/bin/mysqld: ready for connections.
Version: '5.5.48' socket: '/tmp/mysql.sock' port: 3306 Source distribution
我看了下好像是說內(nèi)存大小不夠,但是服務(wù)器的內(nèi)存實(shí)際上是夠的,請(qǐng)問怎么回事
shy_kevin
2016-5-18 21:33
確實(shí)遇到這樣的問題,我的也遇到.每次都需要手動(dòng)啟動(dòng)mysql.
d87904488
2016-5-18 21:57
2#
shy_kevin
是不是 wdcp v3的問題 老是這樣的話怎么能行 網(wǎng)站根本沒法弄
2016-5-18 22:30
v3只是一個(gè)獨(dú)立的后臺(tái)管理,跟mysql有什么關(guān)聯(lián)?
shy_kevin
2016-5-18 23:22
4#
老大,這個(gè)問題確實(shí)存在.每次都需要重啟mysql.要不然就不行,以前沒有遇到過這樣的問題.
shy_kevin
2016-5-18 23:32
3#
d87904488
我也在懷疑,每次網(wǎng)站打不開,都需要進(jìn)入V3里面重啟mysql才可以.我也是裝的centos7.0以前的版本從來沒有發(fā)現(xiàn)這個(gè)問題.
luqiqi
2016-6-21 09:01
我也有,wp的程序會(huì)出現(xiàn),其他暫時(shí)沒發(fā)現(xiàn)
xz633
2016-6-22 19:08
我之前也是 ,添加swap就好了
kaoyayy
2016-6-23 09:43
我也是這個(gè)問題,每天都要手動(dòng)開啟mysql服務(wù)就好了
nx61201
2016-6-23 11:48
swap 搞定 沒問題
