標(biāo)題: [求助] 我的機(jī)器 6.2 6.4 7 都不能安裝 都是64位系統(tǒng) [打印本頁(yè)]
作者: 紅領(lǐng)巾    時(shí)間: 2016-5-14 22:10     標(biāo)題: 我的機(jī)器 6.2 6.4 7 都不能安裝 都是64位系統(tǒng)
我的都是64位系統(tǒng)  不管6.2 6.4 還是CENTOS 7 都是這樣的失敗。
有時(shí)候會(huì)提示 ----Install Error: nginx configure err -----------
安裝apache 也是這個(gè)提示 ----Install Error: apache configure err -----------
PHP也是
14 May 21:58:36 ntpdate[4783]: sendto(218.30.114.84): Operation not permitted
14 May 21:58:37 ntpdate[4783]: sendto(218.30.114.84): Operation not permitted
14 May 21:58:38 ntpdate[4783]: sendto(218.30.114.84): Operation not permitted
14 May 21:58:39 ntpdate[4783]: sendto(218.30.114.84): Operation not permitted
14 May 21:58:40 ntpdate[4783]: no server suitable for synchronization found
Sorry, I cannot run apxs.  Possible reasons follow:
1. Perl is not installed
2. apxs was not found. Try to pass the path using --with-apxs2=/path/to/apxs
3. Apache was not built using --enable-so (the apxs usage page is displayed)
The output of /www/wdlinux/apache/bin/apxs follows:
./configure: line 8417: /www/wdlinux/apache/bin/apxs: No such file or directory
configure: error: Aborting
----Install Error: php configure err -----------
作者: admin    時(shí)間: 2016-5-15 00:53
openvz的虛擬機(jī)?
