wdcp后臺打不開。
lurensky
wdcp后臺打不開。
wdcp后臺打不開,修改過端口。
vi /www/wdlinux/wdapache/conf/httpd.conf 打開不對。
login as: root
root@182.92.0.0's password:
Last login: Mon Apr 11 20:22:35 2016 from 222.220.0.0
Welcome to aliyun Elastic Compute Service!
[root@AY140718164752454eefZ ~]# vi /www/wdlinux/wdapache/conf/httpd.conf
E325: ATTENTION
Found a swap file by the name "/www/wdlinux/wdapache/conf/.httpd.conf.swp"
owned by: root dated: Mon Apr 11 19:10:20 2016
file name: /www/wdlinux/wdapache/conf/httpd.conf
modified: YES
user name: root host name: AY140718164xxxx4eefZ
process ID: 18138
While opening file "/www/wdlinux/wdapache/conf/httpd.conf"
dated: Fri Apr 1 00:04:43 2016
(1) Another program may be editing the same file.
If this is the case, be careful not to end up with two
different instances of the same file when making changes.
Quit, or continue with caution.
(2) An edit session for this file crashed.
If this is the case, use ":recover" or "vim -r /www/wdlinux/wdapache/conf/ht
tpd.conf"
to recover the changes (see ":help recovery").
If you did this already, delete the swap file "/www/wdlinux/wdapache/conf/.h
ttpd.conf.swp"
to avoid this message.
-- More --
其他功能正常,就是打不開后臺。
