標(biāo)題: [求助] 求高手看看MYSQL的錯誤日志 [打印本頁]
作者: colin    時間: 2016-1-17 11:30     標(biāo)題: 求高手看看MYSQL的錯誤日志
160117  2:59:16 [Note] Event Scheduler: Purging the queue. 0 events
160117  2:59:16 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: Shutdown complete
160117 02:59:16 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.69/var/sinbad.pid ended
160117 02:59:55 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.69/var
160117  2:59:55 [Note] Event Scheduler: Loaded 0 events
160117  2:59:55 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: ready for connections.
Version: '5.1.69'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
160117  3:12:05 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: Normal shutdown
160117  3:12:05 [Note] Event Scheduler: Purging the queue. 0 events
160117  3:12:05 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: Shutdown complete
160117 03:12:05 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.69/var/sinbad.pid ended
160117 03:12:47 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.69/var
160117  3:12:47 [Note] Event Scheduler: Loaded 0 events
160117  3:12:47 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: ready for connections.
Killed
160117 06:21:56 mysqld_safe Number of processes running now: 0
160117 06:21:56 mysqld_safe mysqld restarted
160117  6:21:57 [Note] Event Scheduler: Loaded 0 events
160117  6:21:57 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: ready for connections.
Killed
160117 06:22:00 mysqld_safe Number of processes running now: 0
160117 06:22:00 mysqld_safe mysqld restarted
160117  6:22:00 [Note] Event Scheduler: Loaded 0 events
160117  6:22:00 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: ready for connections.
Killed
160117 06:23:08 mysqld_safe Number of processes running now: 0
160117 06:23:08 mysqld_safe mysqld restarted
160117  6:23:08 [Note] Event Scheduler: Loaded 0 events
160117  6:23:08 [Note] /www/wdlinux/mysql-5.1.69/libexec/mysqld: ready for connections.
作者: admin    時間: 2016-1-17 16:46
這是正常日志
作者: colin    時間: 2016-1-17 19:57
謝謝老大!
作者: Jocsonme    時間: 2017-6-16 11:08
    錯誤日志要在哪里看的?我想看看執(zhí)行的SQL錯誤。
作者: admin    時間: 2017-6-16 13:31
可以開啟慢查詢,看一些查詢時間長,可能導(dǎo)致錯誤的問題
