標(biāo)題: [求助] 各位大神,Mysql 老是自動(dòng)卡機(jī)過一會(huì)自動(dòng)重啟,錯(cuò)誤日志如下! [打印本頁]
作者: l9ong    時(shí)間: 2015-12-28 21:36     標(biāo)題: 各位大神,Mysql 老是自動(dòng)卡機(jī)過一會(huì)自動(dòng)重啟,錯(cuò)誤日志如下!
  1. 151228 20:22:56 mysqld_safe Number of processes running now: 0
  2. 151228 20:22:56 mysqld_safe mysqld restarted
  3. 151228 20:22:56 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  4. 151228 20:22:56 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  5. 151228 20:23:04 [Note] Event Scheduler: Loaded 0 events
  6. 151228 20:23:04 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  7. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  8. 151228 20:26:24 mysqld_safe Number of processes running now: 0
  9. 151228 20:26:24 mysqld_safe mysqld restarted
  10. 151228 20:26:33 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  11. 151228 20:26:33 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  12. 151228 20:26:35 [Note] Event Scheduler: Loaded 0 events
  13. 151228 20:26:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  14. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  15. 151228 20:29:20 mysqld_safe A mysqld process already exists
  16. 151228 20:33:04 mysqld_safe Number of processes running now: 0
  17. 151228 20:33:07 mysqld_safe mysqld restarted
  18. 151228 20:33:09 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  19. 151228 20:33:09 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  20. 151228 20:33:09 [Note] Event Scheduler: Loaded 0 events
  21. 151228 20:33:09 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  22. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  23. 151228 20:36:38 mysqld_safe Number of processes running now: 0
  24. 151228 20:36:38 mysqld_safe mysqld restarted
  25. 151228 20:36:39 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  26. 151228 20:36:39 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  27. 151228 20:36:43 [Note] Event Scheduler: Loaded 0 events
  28. 151228 20:36:43 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  29. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  30. 151228 20:44:09 mysqld_safe Number of processes running now: 0
  31. 151228 20:44:13 mysqld_safe mysqld restarted
  32. 151228 20:44:21 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  33. 151228 20:44:21 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  34. 151228 20:44:21 [Note] Event Scheduler: Loaded 0 events
  35. 151228 20:44:21 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  36. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  37. 151228 20:46:16 mysqld_safe Number of processes running now: 0
  38. 151228 20:46:16 mysqld_safe mysqld restarted
  39. 151228 20:46:23 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  40. 151228 20:46:23 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
  41. 151228 20:46:24 [Note] Event Scheduler: Loaded 0 events
  42. 151228 20:46:24 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  43. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  44. 151228 20:46:40 mysqld_safe A mysqld process already exists
  45. 151228 20:49:09 mysqld_safe A mysqld process already exists
  46. 151228 20:56:44 mysqld_safe A mysqld process already exists
  47. 151228 21:04:17 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
  48. 151228 21:04:17 [Note] Event Scheduler: Purging the queue. 0 events
  49. 151228 21:04:19 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
  50. 151228 21:04:19 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/iZ25d2up3riZ.pid ended
  51. 151228 21:04:20 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
  52. 151228 21:04:20 [Note] Event Scheduler: Loaded 0 events
  53. 151228 21:04:20 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  54. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  55. 151228 21:04:33 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
  56. 151228 21:04:33 [Note] Event Scheduler: Purging the queue. 0 events
  57. 151228 21:04:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
  58. 151228 21:04:35 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/iZ25d2up3riZ.pid ended
  59. 151228 21:04:35 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
  60. 151228 21:04:35 [Note] Event Scheduler: Loaded 0 events
  61. 151228 21:04:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
  62. Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
  63. 151228 21:20:24 mysqld_safe A mysqld process already exists
這是怎么回事呀~~
