標題: [求助] wdcp升級php出錯按大神提示安裝iconv_ins依然出錯 [打印本頁]
作者: tonyyu    時間: 2015-12-1 14:39     標題: wdcp升級php出錯按大神提示安裝iconv_ins依然出錯
  1. /root/php-5.3.29/ext/iconv/iconv.c:254: error: ‘_libiconv_version’ undeclared (first use in this function)
  2. /root/php-5.3.29/ext/iconv/iconv.c:254: error: (Each undeclared identifier is reported only once
  3. /root/php-5.3.29/ext/iconv/iconv.c:254: error: for each function it appears in.)
  4. make: *** [ext/iconv/iconv.lo] Error 1
  5. make err
  6. You have new mail in /var/spool/mail/root
  7. [root@AY************b ~]# /root/php-5.3.29/ext/iconv/iconv.c: In function ‘zm_startup_miconv’:
  8. -bash: /root/php-5.3.29/ext/iconv/iconv.c:: No such file or directory
  9. [root@AY************b ~]# /root/php-5.3.29/ext/iconv/iconv.c:254: error: ‘_libiconv_version’ undeclared (first use in this function)
  10. -bash: syntax error near unexpected token `('
  11. [root@AY************b ~]# /root/php-5.3.29/ext/iconv/iconv.c:254: error: (Each undeclared identifier is reported only once
  12. -bash: syntax error near unexpected token `('
  13. [root@AY************b ~]# /root/php-5.3.29/ext/iconv/iconv.c:254: error: for each function it appears in.)
  14. -bash: syntax error near unexpected token `)'
  15. [root@AY************b ~]# make: *** [ext/iconv/iconv.lo] Error 1
  16. -bash: make:: command not found
復制代碼
然后按網(wǎng)友提示安裝iconv_ins提示:
  1. iconv_ins.sh: line 14: ./configure: Permission denied
  2. make: *** No targets specified and no makefile found.  Stop.
  3. [root@AY************b ~]#  No targets specified and no makefile found. ^C
復制代碼
大神什么原因,求破
作者: popox    時間: 2015-12-5 23:44
也是遇到這個問題
搞了幾個小時,終于發(fā)現(xiàn)問題,解決。
bash ./configure: Permission denied
原因:wdcp的云鎖阻止導致的,我們要先去卸載云鎖再安裝。
如何卸載云鎖?
ssh連接上去,執(zhí)行 /usr/local/yunsuo_agent/uninstall 等會就成功卸載云鎖了。
作者: admin110    時間: 2015-12-6 15:14
回復 2# popox
   多謝  以解決!
作者: liuxianglin    時間: 2016-2-25 16:25
太坑爹了,還好看到了。
作者: appcloud    時間: 2016-6-1 15:18
同事這個問題,坑了我一晚上。。。
作者: cai3333    時間: 2016-7-20 02:42
他娘的,坑了我二晚上。。。
