標(biāo)題: [求助] 求助Install Error: wdcp install err [打印本頁(yè)]
作者: a116934411    時(shí)間: 2015-10-10 14:11     標(biāo)題: 求助Install Error: wdcp install err
pureftpd installing...
cp: `/www/wdlinux/mysql/lib/mysql/libdbug.a' and `/usr/lib/libdbug.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libheap.a' and `/usr/lib/libheap.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmyisam.a' and `/usr/lib/libmyisam.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmyisammrg.a' and `/usr/lib/libmyisammrg.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysqlclient.a' and `/usr/lib/libmysqlclient.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysqlclient.la' and `/usr/lib/libmysqlclient.la' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysqlclient_r.a' and `/usr/lib/libmysqlclient_r.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysqlclient_r.la' and `/usr/lib/libmysqlclient_r.la' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysqld.a' and `/usr/lib/libmysqld.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmystrings.a' and `/usr/lib/libmystrings.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libmysys.a' and `/usr/lib/libmysys.a' are the same file
cp: `/www/wdlinux/mysql/lib/mysql/libvio.a' and `/usr/lib/libvio.a' are the same file
ln: creating symbolic link `/etc/init.d/pureftpd': Permission denied
tar: bin/wd_app: Cannot change mode to rwxr-xr-x: Permission denied
tar: bin/wd_sys: Cannot change mode to rwxr-xr-x: Permission denied
tar: bin/wdcp_update: Cannot change mode to rwx--x--x: Permission denied
tar: Exiting with failure status due to previous errors
----Install Error: wdcp install err -----------
