Configuring extensions
checking size of long... (cached) 8
checking size of int... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for sys/types.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for strtoll... yes
checking for atoll... yes
checking for strftime... (cached) yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... no
checking for DSA_get_default_method in -lssl... yes
checking for pkg-config... /usr/bin/pkg-config
checking for OpenSSL version... >= 0.9.6
checking for CRYPTO_free in -lcrypto... yes
checking for SSL_CTX_set_ssl_version in -lssl... yes
checking for PCRE support... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.19.7
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... no
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for CRYPTO_free in -lcrypto... (cached) yes
checking for SSL_CTX_set_ssl_version in -lssl... (cached) yes
checking for GD support... yes
checking for the location of libjpeg... yes
checking for the location of libpng... yes
checking for the location of libXpm... no
checking for FreeType 1.x support... no
checking for FreeType 2... yes
checking for T1lib support... no
checking whether to enable truetype string function in GD... yes
checking whether to enable JIS-mapped Japanese font support in GD... no
checking for fabsf... yes
checking for floorf... yes
configure: error: libjpeg.(a|so) not found.
Setting up Install Process
Package libjpeg-turbo-1.2.1-3.el6_5.x86_64 already installed and latest version
Nothing to do
1. cp -frp /usr/lib64/libjpeg.* /usr/lib/ #configure:error:libjpeg.(a|so) not found ˆóåe¸ã¶¨
2. ×¢Òâß^³ÌÖÐ߀•þÌáʾ" Configure: error: libpng.(also) not found."åeÕ`,½â›QÞk·¨ºÍÉÏÃæµÄÒ»˜Ó.
cp -frp /usr/lib64/libpng* /usr/lib/
Build complete.
Installing PHP SAPI module: cgi
Installing PHP CGI binary: /www/wdlinux/nginx_php-5.2.17/bin/
Installing FPM config: /www/wdlinux/etc/php-fpm.conf
(installing as php-fpm.conf.default)
Installing init.d script: /www/wdlinux/nginx_php-5.2.17/sbin/php-fpm
Installing PHP CLI binary: /www/wdlinux/nginx_php-5.2.17/bin/
Installing PHP CLI man page: /www/wdlinux/nginx_php-5.2.17/man/man1/
Installing build environment: /www/wdlinux/nginx_php-5.2.17/lib/php/build/
Installing header files: /www/wdlinux/nginx_php-5.2.17/include/php/
Installing helper programs: /www/wdlinux/nginx_php-5.2.17/bin/
program: phpize
program: php-config
Installing man pages: /www/wdlinux/nginx_php-5.2.17/man/man1/
page: phpize.1
page: php-config.1
Installing PEAR environment: /www/wdlinux/nginx_php-5.2.17/lib/php/
[PEAR] Archive_Tar - already installed: 1.3.7
[PEAR] Console_Getopt - already installed: 1.2.3
[PEAR] Structures_Graph- already installed: 1.0.3
[PEAR] XML_Util - already installed: 1.2.1
[PEAR] PEAR - already installed: 1.9.1
Wrote PEAR system config file at: /www/wdlinux/nginx_php-5.2.17/etc/pear.conf
You may want to add: /www/wdlinux/nginx_php-5.2.17/lib/php to your php.ini include_path
Installing PDO headers: /www/wdlinux/nginx_php-5.2.17/include/php/ext/pdo/
php-fpm: unrecognized service
php reinstall is OK
šgÓ¹âÅR WDlinux¹Ù·½Õ“‰¯ (http://ahbydz.com/bbs/) | Powered by Discuz! 7.2 |
