標(biāo)題: [求助] 更新了php的遠(yuǎn)程DOS漏洞 php-fpm啟動(dòng)不了啊 [打印本頁(yè)]
作者: hb139    時(shí)間: 2015-6-27 16:20     標(biāo)題: 更新了php的遠(yuǎn)程DOS漏洞 php-fpm啟動(dòng)不了啊
按照這個(gè)http://ahbydz.com/bbs/thread-38462-1-1.html 操作的
Stopping nginx: [  OK  ]
Shutting down php_fpm . done
Starting nginx: [  OK  ]
Starting php_fpm Error in argument 1, char 1: no argument for option -
Usage: php-cgi [-q] [-h] [-s] [-v] [-i] [-f <file>]
       php-cgi <file> [args...]
  -a               Run interactively
  -C               Do not chdir to the script's directory
  -c <path>|<file> Look for php.ini file in this directory
  -n               No php.ini file will be used
  -d foo[=bar]     Define INI entry foo with value 'bar'
  -e               Generate extended information for debugger/profiler
  -f <file>        Parse <file>.  Implies `-q'
  -h               This help
  -i               PHP information
  -l               Syntax check only (lint)
  -m               Show compiled in modules
  -q               Quiet-mode.  Suppress HTTP Header output.
  -s               Display colour syntax highlighted source.
  -v               Version number
  -w               Display source with stripped comments and whitespace.
  -z <file>        Load Zend extension <file>.
................................... failed
作者: 強(qiáng)追猛進(jìn)    時(shí)間: 2015-9-27 00:47
嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻嘻
