標(biāo)題: [求助] 網(wǎng)站經(jīng)常打不開,多刷新幾下才能開,后臺(tái)查看/var/log/maillog [打印本頁]
作者: tearky    時(shí)間: 2015-6-18 18:40     標(biāo)題: 網(wǎng)站經(jīng)常打不開,多刷新幾下才能開,后臺(tái)查看/var/log/maillog
Jun 18 16:49:24 iZ23yx9plecZ sendmail[9868]: t5I8nNV8009868: from=www, size=957, class=0, nrcpts=1, msgid=<201506180849.t5I8nNV8009868@iZ23yx9plecZ>, relay=www@localhost
Jun 18 16:49:24 iZ23yx9plecZ sendmail[9868]: t5I8nNV8009868: to=948835597@qq.net, ctladdr=www (1000/1000), delay=00:00:01, xdelay=00:00:00, mailer=relay, pri=30957, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jun 18 17:24:26 iZ23yx9plecZ sendmail[10035]: My unqualified host name (iZ23yx9plecZ) unknown; sleeping for retry
Jun 18 17:25:26 iZ23yx9plecZ sendmail[10035]: unable to qualify my own domain name (iZ23yx9plecZ) -- using short name
Jun 18 17:25:26 iZ23yx9plecZ sendmail[10035]: t5I9PQdn010035: from=www, size=969, class=0, nrcpts=1, msgid=<201506180925.t5I9PQdn010035@iZ23yx9plecZ>, relay=www@localhost
Jun 18 17:25:26 iZ23yx9plecZ sendmail[10035]: t5I9PQdn010035: to=499968901@qq.com, ctladdr=www (1000/1000), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30969, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jun 18 18:08:20 iZ23yx9plecZ sendmail[10383]: My unqualified host name (iZ23yx9plecZ) unknown; sleeping for retry
Jun 18 18:08:24 iZ23yx9plecZ sendmail[10391]: My unqualified host name (iZ23yx9plecZ) unknown; sleeping for retry
Jun 18 18:08:25 iZ23yx9plecZ sendmail[10398]: My unqualified host name (iZ23yx9plecZ) unknown; sleeping for retry
Jun 18 18:08:35 iZ23yx9plecZ sendmail[10407]: My unqualified host name (iZ23yx9plecZ) unknown; sleeping for retry
作者: tearky    時(shí)間: 2015-6-19 16:24
Jun 19 15:56:59 iZ23yx9plecZ sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/safe ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sr.php
Jun 19 15:57:11 iZ23yx9plecZ sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ;
Jun 19 15:57:11 iZ23yx9plecZ sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
Jun 19 15:57:43 iZ23yx9plecZ sudo:    wdcpu : problem with defaults entries ; TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ;
Jun 19 15:57:43 iZ23yx9plecZ sudo:    wdcpu : TTY=unknown ; PWD=/www/wdlinux/wdcp/sys ; USER=root ; COMMAND=/www/wdlinux/wdphp/bin/php /www/wdlinux/wdcp/task/wdcp_sv.php
作者: wdy876688758    時(shí)間: 2016-10-2 09:31
我也是這種情況!
作者: joejoes    時(shí)間: 2016-12-13 22:15
是不是有人在攻擊?
