標(biāo)題: [教程] linux下的rar文件解壓 [打印本頁]
作者: admin    時間: 2012-10-14 14:11     標(biāo)題: linux下的rar文件解壓
rar壓縮文件是在windows用得最多的一個壓縮文件或格式
有時,也會用在Linux下,但Linux下默認(rèn)是不支持這個格式的
對zip的格式,倒還是可以支持的
所以,一般都可以在win用壓縮成zip,然后在linux下就可以用了
對于一定要用到rar的,還是可以的
只要安裝個rar軟件就可以
rar的linux官網(wǎng),可以看這里
http://www.rarlab.com/download.htm
可以下載最新版的,不過據(jù)我測試的,最新版要球gblic是2.7以上的
但在CentOS 5.X系統(tǒng)里,是2.5的,所以不用下最新版的
以wdOS 1.0為例,wdOS 1.0是基于CentOS 5.8的
只能用較低的版本,如下
wget http://www.rarlab.com/rar/rarlinux-3.6.0.tar.gz
tar zxvf rarlinux-3.6.0.tar.gz
cd rar
make
這樣就完成了
然后就可以解壓了
運(yùn)行
rar x file.rar
這樣就完了
x是參數(shù)
file.rar是相應(yīng)的文件
更多的功能和參數(shù),可看
RAR 3.60   Copyright (c) 1993-2006 Alexander Roshal   5 Aug 2006
Shareware version         Type RAR -? for help
Usage:     rar <command> -<switch 1> -<switch N> <archive> <files...>
               <@listfiles...> <path_to_extract\>
<Commands>
  a             Add files to archive
  c             Add archive comment
  cf            Add files comment
  ch            Change archive parameters
  cw            Write archive comment to file
  d             Delete files from archive
  e             Extract files to current directory
  f             Freshen files in archive
  i[par]=<str>  Find string in archives
  k             Lock archive
  l[t,b]        List archive [technical, bare]
  m[f]          Move to archive [files only]
  p             Print file to stdout
  r             Repair archive
  rc            Reconstruct missing volumes
  rn            Rename archived files
  rr[N]         Add data recovery record
  rv[N]         Create recovery volumes
  s[name|-]     Convert archive to or from SFX
  t             Test archive files
  u             Update files in archive
  v[t,b]        Verbosely list archive [technical,bare]
  x             Extract files with full path
<Switches>
  -             Stop switches scanning
  ad            Append archive name to destination path
  ag[format]    Generate archive name using the current date
  ap<path>      Set path inside archive
  as            Synchronize archive contents
  av            Put authenticity verification (registered versions only)
  av-           Disable authenticity verification check
  c-            Disable comments show
  cfg-          Disable read configuration
  cl            Convert names to lower case
  cu            Convert names to upper case
  df            Delete files after archiving
  dh            Open shared files
  ds            Disable name sort for solid archive
  e[+]<attr>    Set file exclude and include attributes
  ed            Do not add empty directories
  en            Do not put 'end of archive' block
  ep            Exclude paths from names
  ep1           Exclude base directory from names
  ep3           Expand paths to full including the drive letter
  f             Freshen files
  fcu[file]     Read archive comment from Unicode file
  hp[password]  Encrypt both file data and headers
  id[c,d,p,q]   Disable messages
  ierr          Send all messages to stderr
  ilog[name]    Log errors to file (registered versions only)
  inul          Disable all messages
  isnd          Enable sound
  k             Lock archive
  kb            Keep broken extracted files
  m<0..5>       Set compression level (0-store...3-default...5-maximal)
  mc<par>       Set advanced compression parameters
  md<size>      Dictionary size in KB (64,128,256,512,1024,2048,4096 or A-G)
  ms[ext;ext]   Specify file types to store
  n<file>       Include only specified file
  n@            Read file names to include from stdin
  n@<list>      Include files in specified list file
  o+            Overwrite existing files
  o-            Do not overwrite existing files
  ol            Save symbolic links as the link instead of the file
  or            Rename files automatically
  ow            Save or restore file owner and group
  p[password]   Set password
  p-            Do not query password
  r             Recurse subdirectories
  r0            Recurse subdirectories for wildcard names only
  s[<N>,v[-],e] Create solid archive
  s-            Disable solid archiving
  sfx[name]     Create SFX archive
  si[name]      Read data from standard input (stdin)
  sl<size>      Process files with size less than specified
  sm<size>      Process files with size more than specified
  t             Test files after archiving
  ta<date>      Process files modified after <date> in YYYYMMDDHHMMSS format
  tb<date>      Process files modified before <date> in YYYYMMDDHHMMSS format
  tk            Keep original archive time
  tl            Set archive time to latest file
  tn<time>      Process files newer than <time>
  to<time>      Process files older than <time>
  ts<m,c,a>[N]  Save or restore file time (modification, creation, access)
  u             Update files
  v             Create volumes with size autodetection or list all volumes
  v<size>[k,b]  Create volumes with size=<size>*1000 [*1024, *1]
  ver[n]        File version control
  vn            Use the old style volume naming scheme
  vp            Pause before each volume
  w<path>       Assign work directory
  x<file>       Exclude specified file
  x@            Read file names to exclude from stdin
  x@<list>      Exclude files in specified list file
  y             Assume Yes on all queries
  z[file]       Read archive comment from file
wdl_knows
作者: qq682907    時間: 2012-10-16 14:12
我昨晚安裝了 7z 壓縮比更加好 支持rar 和zip
作者: happyboy    時間: 2013-3-26 09:22
好的,學(xué)習(xí)了
